Is this on a lift or just sitting on their own weight!? Those coils look oem how they sit.
Did you do aftermarket sway bar links to account for the difference in height?
Switched it out back to oem? Or to another one?on my '19 laramie 1500 I switched out to the Helwig.
1/8 isn’t really enough to make a difference IMO, but its a pita to measure for sure. I went through this same process with my last two jeeps after lifting them. Spent a mess of money on adjustable track bars before really knowing what i actually needed. But you could always throw that bracket on and see of it over corrects it or dieals it in perfectly.I tried my best to measure my the difference with axle offset/alignment but it’s really hard to tell. Since the rear is lifted 1 3/4” I am seeing that the axles is offset towards the passenger side ever so slightly. Maybe 1/8” difference side to side.
I am going to watch some videos to see how the best way to check rear alignment after a lift to see if there is a more successful way of verifying.
My parts come in today for the track bar relocation kit.
That’s what I use too. Without it my camper would not be towable above 55mph. Plus it’s super easy to hook up and unhook.I use the pro pride hitch on my TT. I'll never tow without it again. It makes a huge difference. I actually let my wife drive cruising 70 mph on the interstate. They are expensive but so would an accident so it's actually cheap insurance. It
You gained it in the front!? I thought those came with oem springs and were set to the no loft height…Somehow I only gained 1”. Something’s off. Prolly my math.
