look forward to hearing you experience with them! I mayyyyy try the 893xhds sice you didnt. im hesitent since I dont want 2in in the rear and dont really want to have to do a new rear trac bar or anything. What are all the parts you ordered for specifically? When i used to lift Jeeps at or over 2in you needed a new trac bar to re center the rear axle, but the parts you have listed from bam are all different to me.I ended up doing the 350-905xhd’s. I should get 2.5” of rear lift if others are right. If I do then I will lift the front 3” to offset the rake a little.
My ram 2500 rear ground to fender was 43”. My 2024 1500 stock rear is 39” without the 1” spacer I added.
