TheWaterman83
- Dec 31, 2021
Really, there would be no difference in the install except that you have two higher settings on the front struts to choose from. Using these higher settings would put you at the same height in front as an ORP. If you wanted the same for the rear you could go with 1 inch longer/taller springs or a spacer.
This. It defaults back to just measuring your current rake.
Anything above the stock rake level will leave it nose high and you will need spacers or taller springs in the rear like H2OMAN said.
