My truck went into the shop about 3 months ago for the check engine light being on. They said the damper that opens on acceleration was stuck so i figured that wouldve fixed the humm but i guess not.Im very frustrated, but don’t want to lose upwards to 10k trading it in and buying another. I’m trying a K&N intake as a long shot (others have said it helps with reducing vibration at 2000 RPM), and adding the V6 diesel steering wheel damper behind the air bag - to reduce the vibrations at the wheel. I’m also told that there is a damper on the V6 diesel at the front differential. I’m having trouble finding that part but will likely try that as well when I do find it. The diesel also has a transfer case damper but we can’t bolt that to the gas V6 transfer case.
I've been trying to figure out this humming for over a year now. I owned a lifted jeep with mud tires that was more quiet than this truck. I finally had a guy from a muffler shop take a test drive with me and he could definitely here the drone noise. He said he would add a resonator to quiet the drone down. I will update when installed.I have two vehicles. A 2019 Ram with the V6 and a little BMW convertible with a 3 liter straight 6. If I am turning 3K rpm in the convertible I don't hardly hear the engine. I am always between 2,000 and 3,000 rpm om the highway. I've even cruised for over 50 miles in 4th (of a 6 speed) at 70mph before. I was tired and not terribly attentive but it is pretty quiet. My Ram is under 2,000rpm cruising at 70 mph but a steep hill can cause it to downshift and turn a little over 2,000 rpm. That is noticable. But it isn't really working all that hard, but it kind of sounds like it is.omegle webcam chatiw bazoocams
I think a good part of why some object to the V6 is the noticable sound from the engine when cruising. I think Ram has the sound deadening tuned to the more torquey V8. Does that make sense? I don't think my Ram is underpowered but the noticable downshifts may create a different impression.
Do you think the damper is vibrating loose with those style clamps? I just see some daylight on the clamps where it isn't fully wrapping the pipe. Possibly use a style that wraps/hugs the entire circumference of the pipe like the style you have on your clamp on resonator to give it a nice snug fit? I'm following this and hoping you find a solution that at least makes it less noticeable if not alleviates the vibration all together!Yeah, it was colder today and my exhaust damper wasn’t as effective. I loosened all the exhaust clamps/joints and retightened when the exhaust was warm to try and help adjust and reduce vibrations. I really need to figure out how to reduce the vibrations transferring from the motor to the front differential. The motor, to the front diff, to the wheel hubs and back up the steering gear - causing vibration on the wheel, pedal and floor. It might not be something that can be fixed, but I’m going to try.
What exactly was the one you used and where/how did you place it? Just trying to get an idea to decide if it's something I would try. Obviously will wait to see what time will bring with more testing of this configuration before making any decisions. Thanks!Okay, so today I took a different approach and tried one of those auger style mufflers you can buy on Amazon to see if it would help reduce the noise/vibration. I was nervous that it would be to restrictive - but it has considerably reduced exhaust noise and vibration - not eliminated, but better. And this might be the placebo affect, but the truck seems to be a little more responsive in the low end? More driving/testing needed...
Awesome. Thanks for the info! I was getting a little nervous when people online were cutting into their exhausts and welding etc to install these but seems pretty straight forward to install in the RAM exhaust. Hoping it proves to be a good solution to at least make it less noticeable! Drove into a pretty stiff headwind this weekend on the highway and what do ya know... right at 2k RPM the entire tripThis is the one I purchased.
Amazon.com: Patriot Exhaust H3843 Side Tube Muffler Insert: Automotive
Buy Patriot Exhaust H3843 Side Tube Muffler Insert: Mufflers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I took off the pipe bolts to the muffler and tapped it in that pipe with a hammer. It took some patience to get it in there just right, and not in there far enough that I wouldn’t be able to take it out, if needed. It’s a snug fit, I don’t think it’ll move, or need any spot welds.
initial findings are promising. Crossing my fingers this is a good solution. Cheapest of all things I’ve tried thus far.
Yeah, so far I think my main problem is the exhaust vibrations. It idles just fine and I only hear and feel the vibrations in the pedal and floor at the 2k RPM. May just order the auger muffler since it's cheap and see if it helps. Thanks for all your troubleshooting!I feel your pain - I do like this truck aside from the buzz/vibration. I think the exhaust is to blame for some but I also believe the driveline is contributing - I just don’t know where to start with that. With mine, even when at idle the intake and front axle have a significant vibration. The steering wheel damper does help reduce the feeling in the wheel, and adjusting the seat and pedals a bit can reduce the feeling there as well.
