2025 1500 with transmission issues/disappointing
Just looking to get a number of people having a very clunky transmission with the 25s. I have an appointment set with my dealer in 2 weeks.
Sometimes it feels like the torque converter is disengaging and re engaging when cruising on the highway or around town. Get this road bump feel. 7th and 8th gear.
4th to 5th can be rough, sometimes it’s smooth sometimes it just clunks to 5th.
3rd or 4th slow speed. Let off the throttle and you get tons of decel feel and a jerk when you get back on the throttle accompanied by a metallic clunk.
Intermittent surging in 3rd when applying steady throttle at slow speed.
4/3 harsh
3/2 harsh
1200 miles now. Started acting up around 300 miles.
2025 3.0, 3100 miles same issue. Dealer owes me a wheel lug key so I'm be dropping it off to complain about this and get it documented.
The only hope for a fix is a large volume of complaints about the same issue. The least we'll get is software if enough of us complain. New transmission calibration is probably all that's needed. It's definitely different than my 2022 5.7.
My 2025 also has the clunky trans. Either a downshift or going slow and taking my foot off accelerator makes it feel like a manual transmission in the wrong gear. Dealer has had it once already, thinking of switching dealers at this point
I have a 3.0 2025 Bighorn. It has 2800miles. Been a shaky mess the whole time. They balanced tires but didnt help. More i drove it more i realized it is likely torque converter. 1st gear stop and go traffic is dangerous it surges at slightest throttle touch then jerks back. Then it shakes as you pick up speed and 50mph and up throttle tip in gives a stutter and shake in floor and steering wheel and seat and floor. I go to the dealer tomorrow morning. They said over the phone and that it could be the torque converter pump. We will see. This is supposed to be a 10 year truck for me in so far without passive entry and this shaky mess. I hate driving it every time.
Just an update. Truck also buck’s now in 8th gear at 40 mph. Low rpm.
Dealership said normal characteristics of this truck. 🤦‍♂️
I mean, technically they were right. They didn't say it was "good", they said "normal" - meaning a lot of them do that. 🙁
Just something to consider -Ram gas tanks don’t have baffles in them. Could it be the gas sloshing around? I used to notice it on my first truck at stop signs- a slight nudge. Turns out it was normal. It happened more when the tank was half full.
I have a 33 gallon tank in my 2019, I've never noticed a slosh. At half full, 16.5 gallons times 6.3 pounds per gallon for premium = 104 pounds of fuel, not that much weight.
Any dealer that won't just do warranty work is either stupid or hates money, because warranty work pays their bills.
The dealership that did warranty work for me last, quoted $600 me for parts and labor, but when RAM covered it under warranty, the dealership quoted them $300. If the dealership has enough non-warranty work, I could see why they wouldn't want to do warranty work if they can overcharge the customers.
I drove a '24 and the transmission was just as silky smooth as ZF transmissions have always been in these trucks. And, nobody was complaining about the trans. So what changed for '25? Why would they alter the TCM programming between model years? That doesn't make sense.
A more plausible explanation is that they've started to go "cheap" with the valve body and/or other internal components in a quest to save money. "The Car Guy" on YouTube did several videos recently with Nate from Next Gen Drivetrain about how the OEs are doing that. They're purposefully using inferior parts to help their bottom line. They are ruining what could be excellent transmissions.
There is a tsb to refresh the tcm for the 25 model year. But that needs to be determined if it applies to your specific truck.
Dealership balanced the tires...again....reset the Trans control module and the throttle control module. Nothing has changed, if anything the balancing made it shake at every speed more. Junk. stutters, hard shifts, shakes. worst vehicle. It looks sharp just sitting there in my drive while i drive my 10yo Grand Cherokee ...laughing...crying
I still have a door panel coming in they are going to replace given it was delivered with a damaged door panel. When they do the panel, i'm leaving it with them for however many days/weeks needed and not taking it back until its fixed or i get legal action going. Done
With ac on its worse. Runs great cold wether or short trips battery unhook run great for 150 miles. Mine i will trade in when 3 36 warranty is done. I found shift at 3000 rpm and keep the rpms above 2300 when grabs next gear. So i have to drive fast but i have a rebel with 900 pounds in the bed and i get 17.3 mpg crazy.
4/3 harsh
3/2 harsh
I'm experiencing the same. I have approximately 8,000 miles on my 2025 Ram 1500. Originally it was just when starting or slowly accelerating - like in the neighborhood. Going from 1st - 2nd and then 2nd - 3rd. In the last six weeks or so I am also noticing it during deceleration. I can't say that it's gotten worse, though I think it is, but it's definitely happening more. I'm going to take it back to our dealer because I have a couple of other issues as well. Sometimes it takes a lot of speed to get into the 8th gear. Well over 70 mph. I'm also no where near the published hwy miles. At best I've just squeaked over 20 mpg on the interstate and that's driving very conservatively.
My '25 Limited upshifts and downshifts flawlessly. Going on 11K miles. My '22 Limited, however, every now and again would have a clunky downshift into first. I never took it the dealer because it would never do it consistently.
Different engine, different transmission calibration. Makes perfect sense actually.
2025 Ram Big Horn with 3,300 miles. I believe my dealer applied this tsb for me last week after I got a CEL just turning the truck on while on the way to lunch. Similar symptoms to many here: bit of a shudder while downshifting between third and 2nd, especially on a decline or incline. Issue seemed to be fairly reqular at 1,000 miles, went away for a bit, and reappeared around 2,800 miles. Would also experience almost a cavitation in the transmission in the 40-50 mph range, and that, as well as the shudder issue, seem to have been addressed by the tcm flash, but its been only a week, so I'm not holding my breadth. I can tell that the flash modified some shift points, as its much harder to get into 7th or 8th gear, unless you go through a fairly aggressive acceleration to hit highway speeds. This has had the effect of lessening my MPG this past week, which had been excellent. Anyway, I like the truck, but am a little leery as to its long term prospects for reliability at the moment.
Sounds like they're holding lower gears longer because they can't shift out of 7/8 quickly/smoothly enough.... something I've noticed when trying to pass someone: floor the accelerator and zero response getting out of 7 or 8.
@StuartV - Yea, I was late to work when I picked up the truck and didn't ask any in-depth questions like I usually do; I doubt if they know at this point what caused the BCM to loose its' configuration anyway. Unfortunately the TSB 21-015-25 update ended up making the shifting worse after putting a couple of hundred miles on the flash. I've also seen the Stability Control warning screen appear again with associated warning lights and loss of steering assist, which cleared after parking the truck for a bit and restarting. I have not seen it since, but I don't trust taking this truck anywhere as it could leave me stranded or worse, get into a wreck because of a failure. I'm really regretting this purchase at this point, especially in light of the amount of $$$ we shell out to purchase these products. I did see there is now another TSB (posted below) that actually addresses replacement of the valve body in the transmission instead of applying the software updates that only seem to move the problem to a different speed range or throttle setting. I'm thinking about opening a Star case on this one to ensure this gets addressed as outlined in the TSB; I'll keep you all posted as to how this unfolds.
Dangit man any updates? I swear my dealer thinks im lying 🤬 getting so frustrated with ram
