2025 1500 with transmission issues/disappointing
Agreed, that's my thoughts as well. Will post those when I get home from work today. I don't think I have found all of them yet, but it's a start. Thankfully I work with a bunch of gear heads in the aerospace defense industry that are also RAM fans and want to see this resolved, so I have a lot of brainpower behind getting to the bottom of this issue!
mine is a rebel and my fire wall is covered with a test shed i can't even see those grounds on the pics near the coolant tanks
I have the same issues. It’s maddening. Dealer says it’s normal but I’ve driven several 3.0 Hurricanes and it’s far from normal. Truck drives amazing if I do the negative terminal disconnect for an hour but is back to driving like crap writhing the day. Have any of you found a fix. Please hI
I have the same issues. It’s maddening. Dealer says it’s normal but I’ve driven several 3.0 Hurricanes and it’s far from normal. Truck drives amazing if I do the negative terminal disconnect for an hour but is back to driving like crap writhing the day. Have any of you found a fix. Please help.
another thing its crazy the surge but look at speedo still is accelerating feels like it slow down but its not .I wonder if they fixed it if it would be slower.Like i said before super slow or 3000 rpm higher shifting. I have 900 pounds in my truck bed and i get 4.7 4.8 0 60 times and it shouldn't i think the surging trucks have the wrong program in them hell demons left factory with wrong computer.
I’m so sick of this! Truck drives like absolute crap! According to the dealer, nothing is wrong… I’ve driven 3 different SST Rams at this point and one of them had 4000 miles on it. They were all as smooth as could be. I don’t know what to do. It’s maddening. I’m praying that Ram has a fix here. About to lose my mind.
Well, I don't have a '25 but I just had my '22's transmission replaced and it seems to have solved the issues. I've only driven it a couple times but it didn't exhibit the symptoms it previously had other than just :poop: economy mapping.
Any dealer that won't just do warranty work is either stupid or hates money, because warranty work pays their bills. Take it to another dealer, force a tech to ride with you and recreate the problem for them so there is no denying it.
any new news on your trans mine is the same still bad now its warm again
Have any of you have the dealer look at this? I have an appointment tomorrow for it IMG_0055.png
any luck did you go to dealer
I finally got to the dealer near me to update the TCM on 5/14. (TSB-21-015-25; Thanks Jinx1009 for posting!) They were able to duplicate the issue and performed the flash. As of today and 200 miles on the update, it seems to be shifting more smoothly without the clunks as noted before, though I'm still feeling a "nudge" on the 2-3-4 and 4-3-2 transitions. One interesting thing to note it was pouring rain when I picked up the truck from the dealer and quite cold out at 42 degrees. The next day was considerably warmer and the shifts were still consistent in their "feel" weather cold or hot. Fingers crossed this is a good sign. Going to put more miles on it this weekend and will see if this is the fix I was hoping for; stay tuned. Oh, and I have not gotten the truck up on ramps yet to find the remaining ground points. The one's I have pics of in an earlier post are all I have found to date.
yes i had all of updates to its a little better .
There is a middle rpm it don't like below 2200 rpm shifts are fine if shifting higher rpm when it grabs next gear it has to be above 2200 rpm or its harsh and surgie . Clunk i have owned 10 ram trucks in 20 years some have done it some have not but when driving slow i always push gas pedal softly when first pushing so there is no clunk. What's crazy in the winter no problems and when unhooking batteries 200 mile perfect even if its hot out. GOOD LUCK TO ALL.
After about 300 miles of decent operation after the TSB flash on 5/14, it's back to severe clunking operation up/down in the 1st, 2nd and 3rd gear transitions. I've also had a check engine light on twice, not wanting to shift out of park after shutoff from a hiway drive and continued acceleration even when I lift off throttle in 1st or 2nd gear around town. It's definately getting worse and to the point now where I don't feel it's safe to drive around town. It's back to the dealer after the holiday break to see if there is a fix for it yet as it doesn't appear the software updates are addressing the root cause of the issue. This is getting very frustrating for sure!
That's not safe. Also when its hot out putting ac on makes the issues even worse. Keep me posted good luck.
Agreed! As "luck" would have it, when I hopped in the truck to go to work Tuesday morning after the holiday, I was greeted with a "Service Electronic Stability Control" notification on my central display and had a couple of warning lights illuminated on the dash. I immediately headed up to the dealer to drop it off for service. See the attached images for all the error codes found during the service visit. It does appear they are all related to the Body Control Module not communicating with the other sub-systems on the network. Now that those have been addressed, I picked the truck up this morning and headed into work... everything from the power steering effort to the throttle operation being more linear to the lumpy shift actions of the transmission seem to have been resolved. Of course I have thought this before with the past SW updates, but this time the drive feel is much more "integrated" than before. I only have about 40 miles on this re-flash, so I will post here if I note any improvements/degradations in the performance of the transmission as I put on some miles. I also wanted to give a big shout out to Brandon DCJR dealer in N. Colorado for staying on this without just brushing this off as normal operation, the service team there has been top notch!
That service ticket says that the BCM lost its configuration and the fix was that they restored the configuration.
I would expect the truck to run fine as long as the BCM continues to have its configuration.
But, what caused it to lose its configuration? If they didn't figure that out and fix that, then I would also expect the BCM to lose its configuration again at some point and you be back to a crap-running truck.
If your truck has bad grounds, maybe that's why the BCM lost its configuration?
I have already had that message on my screen too i shut truck off restarted went away any time something goes wrong i have had locks not work batteries die cause keys to close blue cameras screens i shut if right off and put to acc for a few mins i and restart all is fine ts ******** these electronics communicate like crap sorry for run on sentence
@StuartV - Yea, I was late to work when I picked up the truck and didn't ask any in-depth questions like I usually do; I doubt if they know at this point what caused the BCM to loose its' configuration anyway. Unfortunately the TSB 21-015-25 update ended up making the shifting worse after putting a couple of hundred miles on the flash. I've also seen the Stability Control warning screen appear again with associated warning lights and loss of steering assist, which cleared after parking the truck for a bit and restarting. I have not seen it since, but I don't trust taking this truck anywhere as it could leave me stranded or worse, get into a wreck because of a failure. I'm really regretting this purchase at this point, especially in light of the amount of $$$ we shell out to purchase these products. I did see there is now another TSB (posted below) that actually addresses replacement of the valve body in the transmission instead of applying the software updates that only seem to move the problem to a different speed range or throttle setting. I'm thinking about opening a Star case on this one to ensure this gets addressed as outlined in the TSB; I'll keep you all posted as to how this unfolds.
