KWKSLVR
Part of me hopes one of them is a member here so that we can find out what's up.Well, if that's what they think, I really hope I know one of the 22 owners. I'll make Stellantis' life hell.
Me, too. Maybe Stellantis does the right thing and gives these owners a complete refund (taxes included) plus a discount on a new truck/priority for a new build. Of course, seeing as how Stellantis has handled everything else to this point leads me to believe these owners are in for another clustertruck.Part of me hopes one of them is a member here so that we can find out what's up.
Priority build for a MY 23 more likeplus a discount on a new truck/priority for a new build. Of course, seeing as how Stellantis has handled everything else to this point leads me to believe these owners are in for another clustertruck.
18.6 days WS to LotMy dealer told me that production is scheduled to start on my 1500 Rebel GT on Dec 6th. I'm guessing that means it's out around the 13th. Anyone know what transport is averaging (to LA) I know it will vary. Just trying to determine best guess for arrival.
FWIW, I'm still in D, and haven't moved to D1.
Antifreeze protection? You mean like defrosters? Your truck has whatever it needs for winter in new jersey. Definitely defrostersoff topic. I looked in the manual, no luck, and googled. Some of you guys probably know. I took delivery of my truck from mark dodge, in LA, but it's up here in NJ. It's getting cold....Do all trucks come from the factory with the same , and, antifreeze protection, and, if so, to what temperature?? Joeco: you are in the same boat.
If you are concerned you can call the dealership. All new vehicles should come with antifreeze.off topic. I looked in the manual, no luck, and googled. Some of you guys probably know. I took delivery of my truck from mark dodge, in LA, but it's up here in NJ. It's getting cold....Do all trucks come from the factory with the same , and, antifreeze protection, and, if so, to what temperature?? Joeco: you are in the same boat.
I ordered Limited E torque ORG 4x4 Ram Boxes MFT on 6/22.Supposed to go to build finally on 10/25. Then 11/22. Today Ram told my dealer MAYBE in January. Pissed as hell. But I want what I ordered.
Thank you. checked defroster when i posted about recall. works fine. I will check antifreeze today. duh. not sure why I didn't think to look. dIf you are concerned you can call the dealership. All new vehicles should come with antifreeze.
If you need to know now...
Be sure your truck has been off (not running) for several hours. Pop the hood and open the radiator cap if its anything but clear liquid, you have antifreeze. Mopar typically will use a -34°F 50/50 mix for their coolants. DON'T MIX DIFFERENT COOLANTS! They will cause a reaction and gunk up your coolant system.
As far as window defrosters, be sure to test them, there is a very small recall (22 trucks) because they just flat out don't work.
Because the front defrosters are part of your HVAC And thats what was faulty in the recallhow do you check if the defrost function works (and you are not one of the 22) when the car is parked inside at the dealer? Can you maybe feel the back window if it gets a little bit warm? or spray some water on the window and wait?
Non-serious answer: Drive North until it matters.how do you check if the defrost function works (and you are not one of the 22) when the car is parked inside at the dealer? Can you maybe feel the back window if it gets a little bit warm? or spray some water on the window and wait?
Do you verify the power FOLDING mirror stayed with level B. That was an issue for some people.In the process of ordering a 2022 Bighorn Night Edition. Level 2 was changed to Level B. Was told only difference is the under seat storage being included. Also, Ram Boxes, LED lights and BSM all on restriction so can’t get them. Not a deal breaker but kind of kicking myself for not ordering a BTS last year.
the fact is that when you sign the document to make it yours and you find out afterwards, it is maybe more of a hassle then discovering it before leaving the dealer. Just like with all the other things people mentioned her to keep an eye on. Like the rear windowframe cracksNon-serious answer: Drive North until it matters.
Serious answer: The issue is with the HVAC and Front Window Defrost.
(Not sure how you might test as the Defrost may be throwing heat, however in a way that fogs the window instead of heating it.)
