2021 horn not working
Horseman99
Appreciate any thoughts. Horn doesn’t work from Steering wheel or from fob (lock/unlock, alarm). Wiring and fuse are good. Horns work when hot wired. Considering getting alfaobd to run diagnostics If it can do that??
RamCares
Michigan
We recommend reaching out to your local dealer if you haven't done so already. You can find one here: Find a Ram Dealership Near You | Ram Trucks Please don't hesitate to reach back out to us via private message, if you have any more questions or concerns. Thanks.
Chris,
Ram Cares
kapinallinen2
5thGenRams Supporter
Southern Maryland.
If the fuse, wires and grounds check good, then either the horn relay or BCM.
This is how my 2019 is wired.
