2021 1500 Brake Moan when reversing
It's easy, it looks like an oversize muffler clamp and bracket. I installed my kit in about an hour. 75K miles later it still very quiet.
Tom
Wondering how long this “kit” has been out?
Seems like a problem that’s been known about since 2019. Why are 2022’s and likely 2023’s still doing this?🤔
No problem just spend some money on this kit from MOPAR instead of re-engineering and fixing the problem.🙄
Seems like a pattern that just keeps repeating year after year with the same issues. 5 years is plenty of time to fix this stuff.
I believe it started with TSB NUMBER:05-001-19GROUP:05 - Brakes
DATE:February 14, 2019.
Then had few updates with different parts for the kit.
Ridiculous they don’t at least put that on right at the factory if it’s a known problem.
Had mine done 01-14-2020.
Was quiet as a church mouse for over a year, then started to make very slight noise again, but nowhere as bad as it used to be.
I wonder if tightening the bolts on the clamp would help.
I wonder if you can do this without even popping the wheel off... I might order it.
Sent from my SM-G781U1 using Tapatalk
where did you guys all buy this kit if you did it yourselves? I'm seeing $50 plus another 12 for shipping.
