2020 Overland Ram Build
Still in progress of adding all my lighting but here's an update on my Switch Pros SP-9100 and lighting setup. For Pods, since I'm going to be running 8 total and to me I don't need $250 Rigid Pods.. I opted for Nilight which so far have been awesome and all I need. I picked up a couple spares to carry in the truck in case one goes out but I got all 8 of them for less than a pair of the big name brand so I'm content with that.
The 8 Switches will be:
Ditch Lights
Left Side
Right Side
Rear
Rock
RC 6" Grill Spots
All On
*Both Sides
*Temporarily until I figure out what other lighting I want for the last remaining switch.
Installed the Switch Pros controller in headliner (Was a bit nerve racking drilling holes into a brand new truck's headliner!!)
Installed ditch light Spot/ Flood pods on Zroadz hood brackets on the front:
Installed Flood pods onto the Leitner Rack in the rear:
Still to come:
2 more flood pods on each side of the rack, the pair on each side will be wired together for a "Left Lights Button" and a "Right Lights Button" (I'm about 3/4 of the way done installing these)
8 RGB-W Rock Lights (1 above each tire, 1 on each side, 1 in front, 1 in rear)
Pair of Rough Country 6" Grill Spot LED's
Hello, can I ask you what location under the hood you ended up mounting your switch pro? I’m trying to get a general idea . Thanks oh before I forget the strob is bad ***!!!!
It's up on Post #23, I mounted it to the headliner and have had zero issues with it there, I love how accessible it is.
Edit: Just realized I was posting from our Vendor account, but this is Tex_Ram as well!
Great job on your build! I noticed both of our trucks look pretty low when they came stock. Does your 6 inch lift feel and look like a 6 or does it feel more like a 4 inch due to our trucks coming slightly lower than most rams. I have a 3.5 RL on mine and when i pull up to some rams that are stock i feel like mine is only slightly higher. Thanks
I'm in a Ram club so I am next to other Rams all the time and I can say with certainty that it is taller than a 3.5 RL SST lift and sits the same height as other 6" lifts on 5th gens, at stock though I definitely felt like I was lower than other trucks though.
