2019 Ram 1500 Bighorn 4x4 Squeak
BerrierTJ28
I have about 1300 miles on my truck. The truck came with 35s and a level kit up front. Has anyone had a problem with squeaks on small bumps? Mine sounds like it’s the front passenger side.
Billet1500 4x4
California
If they used the ready lift leveling kit with upper control arms it's likely the urethane bushings where the control arm mounts to the frame. They have to be greased before install otherwise they squeak. If the upp arm is tubular and you see a red ring where it attaches to the frame that's probably your squeak.
BerrierTJ28
Thank you. I’ll look into it. Anyway to lube it installed?
Billet1500 4x4
California
If they are indeed the ready lift UCA's, unfortunately no, Ready lift did not install grease zerks at these locations so removal of the UCA is required to grease them. Mine squeak every morning. Last truck had Cognitos with the same issue but they at least had grease zerks, a couple pumps every 3 months or so kept them quiet.
RamCares
Michigan
Hi BerrierTJ28,
We certainly understand why this would be concerning. Please let us know via private message if you decide to address this with your dealer. We’d be happy to have this formally documented and connect you with a case specialist for an additional layer of assistance during that process.
Mark
Ram Social Care Specialist
BerrierTJ28
Hi BerrierTJ28,
Mark
Thank you
troutspinner
SE Pennsylvania
Take notice if it squeaks under slight brake pedal pressure. If it doesn't, then it's the brakes.
I'll be going in this Friday for round 3 of my brake squeak saga. ;). First time they greased the anti-rattle clips. That lasted for a hundred miles. 2nd time they installed an updated pads that have a larger anti-rattle clip. That lasted about 2k miles. Friday, they are replacing the calipers and pads to an updated set. We'll see how that goes. While some people may find something like this frustrating, I have to say that my dealer has been awesome. I know when I go there, they're going to try something to fix it.
RamCares
Michigan
Hi troutspinner,
We're happy to hear that your dealer has been helpful throughout this process. As mentioned to your fellow forum members, if you would like any additional assistance, we would be happy to connect you with a Case Specialist!
Alex
troutspinner
SE Pennsylvania
Hi troutspinner,
Alex
Thanks Alex. I'm in good shape right now. I'll reach out if I need escalation.
BerrierTJ28
Mine has the stock upper control arms but has the leveling spacers up top.
BerrierTJ28
Dealership found the issue. Passenger side strut was defective. They replaced it and problem solved.
