2019 Ram 1500 5th Gen Chirping/Squealing with wind gusts
Mshertzinger
I have a 2019 Ram 1500 5th Gen and get a Chirping / Squealing noise with wind gust, anyone else having this problem? It's impossible for the dealer to replicate
Enclosed a link to a video
RamCares
Michigan
We certainly understand why this would be concerning. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than willing to escalate your situation to a specialist who can work alongside you and your dealer while your truck is in service.
Mark
RamCares
NorthStar
Texas
A very common problem on the 2019 models. Do a search on this forum for “whistle” or “tea kettle” and you’ll find others have the same issue with FCA apparently unable to solve at this point.
OPDave
Yes, I have the same issue. Here is my link from yesterday. It's driving me crazy!
OPDave
I think it's the side mirror, it goes away after I put the mirror "in" then returns when I extend the mirrors back out.
Scram1500
It could also be the door seal in the upper corner near the seat belt. Try putting the fan on recirculate and see if the noise goes away. Do you keep a lot of stuff under your backseat? If so that can block air flow to the rear cab vents which will pressurize the cabin causing seals to leak
Richard320
I’m getting the chirp from the passenger mirror, did anyone figure out anything?
I believe someone did in another thread. He said the door flexes with the mirror and it opens a gap in the weatherstrip. He added some foam somewhere. People asked for a picture to clarify but there never was one posted.
ramjam97
Were you ever able to figure out a solution? Recently purchased a 2019 Ram 1500 and my truck does the same exact thing. The noise seems to come from a centralized area near the dashboard.
Choate
I had this problem for a while. Then after an automatic car wash I got home and realized the entire mirror cover was gone. Went bank and somehow it was there and not damaged. Snapped it back into place and no more whistling. It must have popped out some or not been installed all the way
