- Jul 6, 2023
Hello everyone, it is a pleasure to reconnect with the Ram 1500 owners in the 5thGenRams forum. Today, we would like to introduce the LED bulb sizes for the 2019-2020 Ram 1500.
In this post, we will cover the headlight and fog light options for the 2019-2020 Ram 1500, as well as various exterior and interior lighting options.
Compared to halogen lights, LAplus is remarkably brighter, so you don't have to worry about dim halogen lights obstructing your view of the road ahead. The L-T10 series offers multiple color options for your interior lights, while the L-T20 series provides enough brightness to be used as turn signals or brake lights.
The Different Options for 2019-2020 Ram 1500
● Ram 1500
● Ram 1500 Classic with projector
● Ram 1500 Classic with reflector
Product Spec
Low Beam: LAplus H11/LAplus 9005
LAplus H11 for Ram 1500 and Ram 1500 Classic with reflector
LAplus 9005 for Ram 1500 Classic with projector
High Beam: LAplus 9005
Each bulb of the LAplus series can provide a powerful 30W and 3000LM output, delivering a brightness that is remarkably brighter than factory halogen bulbs, perfect for your 2019-2020 Ram 1500. The 6000K bright white light ensures exceptional visibility on dark roads. Additionally, the 360-degree adjustable socket allows for effortless beam pattern customization to suit your preferences. Furthermore, these bulbs feature an interior driver and compact size, making them incredibly convenient for a hassle-free plug-and-play installation.
Fog lights: LAplus H11/LAplus 9006
LAplus 9006 for Ram 1500 Classic
Just like the headlight bulb recommendation, each bulb of the LAplus series fog light can give out 30W, and 3000LM, eliminating concerns about visual blurring during rainy night travels. The 6000K white light can even penetrate fog, allowing for a safe driving experience. The 360-degree adjustable socket allows for free adjustment of the light beam, while the compact size makes it easy to insert the LED bulbs into the fog light assembly. The IP67 waterproof and dustproof configuration, along with an enhanced heat dissipation system, ensures a longer lifespan for the fog lights.
*For now, you can get 15%~25% off discount to get mentioned LAplus series LED bulbs!
Other Front Exterior LED Lights
Front Turn Signal Lights: T-7443D-CK/T-3157D
T-7443D-CK for Ram 1500
T-3157D for Ram 1500 Classic
The T-7443D-CK and T-3157D are equipped with a convenient switchback function, providing users with both Amber and White lighting options. The 6000K white lights can be used for parking lights or daytime running lights, while the 3000K amber option is perfect for turn signal lights.
Please don't worry about the CK socket, Lasfit has a corresponding method to that. For the T-7443D-CK, owners can enjoy a configuration of 24W and 2400LM, providing ample brightness for various lighting needs. The T-3157D, on the other hand, offers a higher configuration of 28W and 2600LM, ensuring enhanced visibility and effectively alerting pedestrians when the turn signal is activated.
Front Side Marker Lights: L-T10A(Amber)
Each bulb of T10 series is equipped with some 3030 high light beads, capable of providing 400LM brightness, Non-polarity design for plug and play. It can give enough amber light to alert vehicles beside you.
Rear Exterior LED Lights
Backup Lights: L-7443/T-T15
L-7443 for Ram 1500
T-T15 for Ram 1500 Classic
The L-7443 and T-T15 are both capable of emitting a bright white light at 6000K, enhancing visibility for the rear of the vehicle during reverse maneuvers. Additionally, both bulbs are canbus friendly, ensuring compatibility with the vehicle's electrical system.
The L-7443 is designed to provide a total output of 1200LM per set, making it suitable for the Ram 1500. On the other hand, the T-T15 is capable of producing an impressive 1500LM per bulb, specifically tailored for the Ram 1500 Classic.
Brake Lights: L-7443R(Red)
2019-2020 Ram 1500 can get brilliant red by installing L-7443R, 300LM/set is enough to let the rear vehicle notice that you are going to reverse, short size can enable Plug and Play.
Cargo Lights: T-T15
3rd Brake Lights: T-T15R(Red)
The Lasfit T15 bulb is designed to provide a bright output of 2400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights.
Interior LED Lights
Map Lights/Footwell Lights: L-T10
The L-T10 interior light from Lasfit is a versatile option that can be installed in various locations on different vehicles. For the 2019-2020 Ram 1500, it can be installed as a map light or footwell light. The L-T10 features a non-polarity design for easy plug-and-play installation, ensuring an error-free experience. With a configuration of 800LM per set, it provides superior brightness compared to the original halogen lamp.
Additionally, the L-T10 series offers a range of color options, including white, yellow, blue, and green, allowing you to customize your footwell lights according to your preferences and needs.
Dome Lights: L-44MM
The L-44MM festoon bulb from Lasfit is equipped with 8 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the LED bulbs to dissipate heat effectively, thereby extending the lifespan of the headlights.
● Ram 1500
Product Spec
L-7443 for Ram 1500
Cargo Lights: T-T15
Interior LED Lights
Dome Lights: L-44MM
