2019 1500 Rear Step Recall (Part # 82215289AB)
Just got mine replaced at the dealer. They could not find it under my VIN, but replaced it with out any issues. I got mine from mopar, but had the dealer install it
Sorry, was not clear, original was from mopar (one of the online ones). The replacement was supplied by the dealer.
Can you see the part number of you get under the truck ? Mine was built May 2019, has the cast iron step but when it was in the dealer 2 months ago they said no recall.
The problem with this recall is it is not vin specific. When the writer pods your car for write up, it never shows up as a recall tied to your vin. So he thinks you do not have a recall. If you have a step, they need to inspect it to see if it is cast iron. If not, no recall. If it is cast iron, it needs replacement. He needs to go to dealerconnect to check Recall Central for recall V93. There is a link called Recalls, not Global Recall System. It is not in Global Recall Systems. The writer needs to know that. He will find it.
Hi everyone, if you are having trouble setting up an appointment for the recall, send us a private message. I am happy to connect you with a recall specialist to get it set up.
Kaitlin
Ram Cares
