I’m researching what a drive cycle consists of. Some say you must let truck idle from cold start until engine reaches temperature. Then drive 55 mph for 5 miles. Then coast off to shoulder of hwy and let truck sit in gear with foot on brake for 2 minutes. Guess I’ll give that a try. Don’t think I’ve ever driven on hwy at 55mph for any distance. And yes. They charge $37 to inspect your vehicle.
1. Make sure your fuel level is between 1/2 and 3/4 tank.
2. Let the truck sit overnight.
3. Start the truck and let it idle for 5 minutes and with A/C and rear window defrost on.
4. Turn off the A/C (and rear defroster) for the rest of the "cycle".
5. Get on the highway/freeway/open road and hold 55-60 MPH for 5 minutes.
6. Coast down to 20 MPH (don't step on the brake).
7. Accelerate back up to 55-60 MPH and hold that speed for 5 minutes.
8. Pull over and let the truck idle for 5 minutes.
9. When you get back home turn the truck off and let it sit for at least 30 minutes.
I am no professional and don't claim that this is the 'official' cycle but that's the gist of it.
- For the idling parts I've read that the transmission should be in either P, D, or N (depending on what your read).
- Some say to have your headlights on for step #3.
- There are others that also mention driving 25-30 MPH and coming to a complete stop (city/urban driving with stop signs and stop lights). Many don't mention this as you most of us will have to do that anyway going from our house to the freeway.
I will let you Google "OBD drive cycle" and let you decide for yourself what is valid and what is bupkis. One thing I did come across, however, is that FCA has a built-in readiness tester (at least on older models). You can try this out and see if it shows that your flags are not set:
1. Place the ignition to ON, but do not start the engine.
2. The check engine light aka Malfunction Indicator Light (MIL) will turn on for 15 seconds.
3. After 15 seconds, one of two things will happen:
......If the MIL flashes for 10 seconds, and then returns to being fully illuminated, the OBDII sensors are NOT READY and you need to complete the drive cycle.
......If the MIL does not flash and remains fully lit, you are ready to go to the smog station.
This was from a web posting several years ago and would be curious to know if the 5th gens have that same built-in function. If your readiness flags are not set your MIL should flash.
Here are some web pages I pulled heavily from:
In order to determine if your Jeep, Dodge, or Chrysler vehicle is ready for an emissions test, you can either use an OBDII scanner or, if one is not available, check the MIL (check engine light). At A Star Smog, we will use an OBDII scanner to conduct a smog precheck. Turn on the ignition ...
antiochstarsmogcheck.com
A basic drive cycle is critical to car diagnostics and emission tests. Why is the drive cycle important? How to do a drive cycle by yourself? Read for details!
www.nonda.co
