180 degree thermostat
You can leave the computer/fan stock and still see a major benefit by running (for example) a 180. If you want the fan to come on sooner, that is yet another benefit and thing you can do, but it doesn't have to be done to see a benefit.
The 180 by itself is so effective in my usage, I personally don't need to worry about the fan.
Excellent to hear this, thank you👍
Ok, well that was a productive conversation. Im thinking about putting a 190 thermostat in mine. (Maybe 180 but that seems to ruffle some feathers) Hitting over 220 when towing 6k camper in 50* ambient. Would not mind running a bit cooler than that. But, but the computer will add more fuel! Thats ok I have a S&B intake, AWE exhaust suite, catch can and Im into the throttle pedal quite a bit anyway. If anything more fuel is probably a good thing with how opened up my Hemi is. According to our AI overloads 240 is overheating and 250 is critical. A 20* window between “happy engine” and “overheating” is a bit too close for my comfort. Im at 83k on my 2019 5.7 so Im ready for a coolant flush and weighing my options here. From what I gathered from the fragmented conversation is 203* is factory and people see much lower temps with a 180. Im thinking a 190 to keep it closer to factory but reduce coolant temp somewhat while towing.
Also, for the record, I was running an oil filter relocation kit which helped oil and coolant temps somewhat but lowed oil pressure about 5psi and right now it is removed to get new seals. May or may not reinstall.
If you were hitting 220, when towing, with the factory thermostat, going to a 180 or 190 won't prevent it from getting that hot again. Will just extend the time it takes to get that warm. the factory thermostat was fully open by 205, so the only reason it should get hotter than say 210 would be lack of airflow through radiator, or something else in system not up to proper efficiency. Changing the fan turn on speeds, even with factory thermostat will help keep it from hitting 220.
What "major" benefit do you get from a 180 stat exactly??
I do not think its an efficiency problem because it runs 200-210 when not towing. While towing a 6k camper, into the wind no less, i was in either 5th or 6th gear most of the time at 60-65mph. This is 2000-2800 rpms for extended times which just does not happen when not towing a heavy load. Normally its in 8th gear at ~1600 rpm at 70mph. So the constant higher revs increase coolant temp faster, in this case fast enough for it to hit 221* before the tstat opened up which I can tell exactly when it opens because the temps drop back to 205-210 pretty quick. If the tstat opened earlier/lower temp then I don't think it will spike that high because coolant is flowing sooner. Just like if you take the tstat completely out then the engine would never heat up properly. A lower temp tstat is letting the coolant circulate more and thereby removing more heat.
if your tstat is not opening until 221 you might have another issue
