180 degree thermostat
You can leave the computer/fan stock and still see a major benefit by running (for example) a 180. If you want the fan to come on sooner, that is yet another benefit and thing you can do, but it doesn't have to be done to see a benefit.
The 180 by itself is so effective in my usage, I personally don't need to worry about the fan.
Excellent to hear this, thank you👍
Ok, well that was a productive conversation. Im thinking about putting a 190 thermostat in mine. (Maybe 180 but that seems to ruffle some feathers) Hitting over 220 when towing 6k camper in 50* ambient. Would not mind running a bit cooler than that. But, but the computer will add more fuel! Thats ok I have a S&B intake, AWE exhaust suite, catch can and Im into the throttle pedal quite a bit anyway. If anything more fuel is probably a good thing with how opened up my Hemi is. According to our AI overloads 240 is overheating and 250 is critical. A 20* window between “happy engine” and “overheating” is a bit too close for my comfort. Im at 83k on my 2019 5.7 so Im ready for a coolant flush and weighing my options here. From what I gathered from the fragmented conversation is 203* is factory and people see much lower temps with a 180. Im thinking a 190 to keep it closer to factory but reduce coolant temp somewhat while towing.
Also, for the record, I was running an oil filter relocation kit which helped oil and coolant temps somewhat but lowed oil pressure about 5psi and right now it is removed to get new seals. May or may not reinstall.
If you were hitting 220, when towing, with the factory thermostat, going to a 180 or 190 won't prevent it from getting that hot again. Will just extend the time it takes to get that warm. the factory thermostat was fully open by 205, so the only reason it should get hotter than say 210 would be lack of airflow through radiator, or something else in system not up to proper efficiency. Changing the fan turn on speeds, even with factory thermostat will help keep it from hitting 220.
What "major" benefit do you get from a 180 stat exactly??
I do not think its an efficiency problem because it runs 200-210 when not towing. While towing a 6k camper, into the wind no less, i was in either 5th or 6th gear most of the time at 60-65mph. This is 2000-2800 rpms for extended times which just does not happen when not towing a heavy load. Normally its in 8th gear at ~1600 rpm at 70mph. So the constant higher revs increase coolant temp faster, in this case fast enough for it to hit 221* before the tstat opened up which I can tell exactly when it opens because the temps drop back to 205-210 pretty quick. If the tstat opened earlier/lower temp then I don't think it will spike that high because coolant is flowing sooner. Just like if you take the tstat completely out then the engine would never heat up properly. A lower temp tstat is letting the coolant circulate more and thereby removing more heat.
if your tstat is not opening until 221 you might have another issue
S that's not how thermostats work. The amount they flow is pretty much the same whether you have a 160 thermostat or a 210 thermostat. The only thing that changes is when they open. And as bigDodge said, if your thermostat isn't opening until 220 then you may just need a new thermostat. My guess is, that what you are seeing is when the fans kick on and start pulling more air. Lower the setting in the tune for when the fans kick on, and you won't see that spike .
This is not true. When they are closed they flow very little and keep the coolant in the block via bypass ports. If they always flowed the same there would be no point to it. Tstats open when they reach a certain temp and allow the full flow to the radiator. Thats why lower tstats circulate the coolant more often.
You completely misunderstood everything I said. Once they are open the flow rates are the same. A 180 thermostat, fully open by 185, flows the same as a 203 thermostat fully open by 208. If your engine, with a 203 thermostat is hitting 220 degrees, dropping to a 180 thermostat isnt going to prevent that, if no other changes are made. It will just take a little longer to get there.
Flow is the same pressure when open yes, but flow volume is increased due to the Tstat opening earlier in the heat cycle. So it will bring temps down when driving due to the air flow. Sitting in traffic with the fan on, yes it wont be any different than the OEM.
Thanks for all the info guys, im going to start with a flush and a new oem stat and go from there. Maybe grab a 190 tstat and be the test dummy..
Volume doesn't increase. Just timing of when the thermostats open. Your coolant is constantly circulating in the block, and through heater core before thermostat ever opens.
You said you were hitting 220+ when towing. That's not something a lower temp thermostat will fix, unless there is an issue with current thermostat.
The timing will increase volume. More circulation thru radiator per hour. Obviously this works as reported by others who have done the mod. This weekend did 500 miles. 250 towing 6k, 250 unloaded. Just got back from towing 6k 125 miles. Unloaded max temp 209. Loaded up max temp 222. Was 48* ambient today. Real world recording. The temps increase when towing by 13* on a stock OEM system and tune, running an opened up intake and exhaust. Its the RPM which the tune apparently does not account for. The coolant gets to 222 before the full open of the tstat, im guessing because the sensor isnt that close to the tstat, and obviously there are hot spots in the system. While towing 6k lbs trailer, 6th gear 2k-2.5k rpm the system just heats up quicker than the oem tstat can account for so it remains 205-222. When unloaded the system is more like 200-209. Again this is with optimal 50* ambient. Im going to flush the system this week with new coolant to optimize. Just winterized my camper so no more towing for awhile but I will grab a 190 tstat to try in the spring when I start towing again to report back the results. Im expecting a 10* drop in max temps from my research. I should also add I'm running the PPE trans pan which has the cooling fins and +2 quarts of ATF which helps with the trans temps and lowers the oil and coolant temps slightly as well.
Change the fan turn on temps in your tune and you will not see that 222 coolant temp. When the fans don't come on until that temp, it's not a thermostat issue
These temps are at 60-65 mph with around 50* ambient, so plenty of cool air flowing into the radiator. Im not sure a fan is going to add anything at those speeds, but I could be wrong there. Seems like letting the coolant flow to the radiator earlier in the heat cycle / more often would help the spikes. The 203 tstat works great when not towing, right in the temp efficiency zone. But towing max capacity and loaded max the system heats up quicker than the 203 tstat can manage without going over 220. Too bad there isnt a “two stage” thermostat that could be actuated with the tow/haul button.
You do have the active grill shutters that restrict some flow at highway speeds. I can almost guarantee it isn't a thermostat issue. Unless the one you have is failing. Which should show up when not towing as well because the thermostat doesnt know if there is a trailer connected or not
I think my oem thermostat is fine, but it is designed with daily driving in mind. Works fine under normal driving. Towing heavy keeps the RPMs up and in turn heats the coolant up much faster. The coolant temp is going to be hotter at certain engine spots than others, its not exactly the same temp everywhere in the system. I think the heavy towing is heating up the coolant faster than the tstat time to full open so by the time it actually fully flows to the radiator its already over 220. So in theory a tstat that starts to open at a lower temp should avoid the coolant heating as much. Only one way to find out! Its not like a tstat is very hard to change out.
If I am off base here, then what is the root cause of towing a heavy trailer causing the engine to run hotter?
I'd guess cooling capacity or somethings not right in the current cooling system. A lower temp t-stat simply opens sooner but it doesn't increase cooling capacity, only take longer to overheat due to the lower temp t-stat opening sooner.
You may have air in the system or low coolant or some blockage between the radiator and the AC condenser.
The heavy towing is definitely a cause. The engine has to work harder to therefore the cooling system has to work harder. If you haven't disabled the grill shutters, then until the engine gets too hot, they will block some crucial airflow, with engine under constant load. then the efans don't kick on until 224, so that will prevent some cooling under load as well. Especially with the grill shutters closed Changing your thermostat will not fix the issue because the thermostat isn't the issue.
Shouldn't the shutters be wide open at that temp? I see why people remove them now. May put that on the bucket list too. From what others say that have done the tstat is it def brings down temps across the board. I get that no matter what tstat is in there the system still has a hard limit on max capacity. Coolant is right on par in the expansion tank. Doing a coolant flush tomorrow and refill with some of this. Will report how the system responds.
