asgadf/lkjnadsfg
- Sep 26, 2021
For those of you who have the 12 inch screen in your truck, what are your thoughts on it? Super cool? Over rated? Something in between?
Same here.I love it on my 2020. And I would have not got the truck without it.
I honestly didn't want it on my 2019 Longhorn but couldn't get it without it. I decided I could live with it since it did have several "real" buttons for things like climate control so I don't have to dig through menus. 2 years later, my biggest gripes are
I don't know if I would have bought this truck if I had known about these problems. At least this forum helped me figure out the running board problem and now I just found a TSB for the grinding noise when turning right at slow speeds.
- No hard buttons for things like seat heat/cool, steering wheel heat, deploy running boards
- No way to manually reset the system when it inevitably glitches. Have to pull a fuse or disconnect battery
- When your battery dies due to some other glitch (most recently discovered it was due to running boards), the thing loses half its functionality so you have no cameras, seat heat/cool, climate control, etc until it does something to restore that functionality. On new year's day this year I got up at dark 30 to go the hunting camp and battery dead. Have to disconnect battery to jump it off because it won't crank (seemed like fuel pump shutoff or something). Finally get it cranked then drive 2 hours and back into a small tree while turning around because no cameras
Yes I should have looked closer when backing up but why do the cameras not work after a power loss???
2 is incorrect. 3 is partially incorrect if you force a system reboot, which you can do (see #2).I honestly didn't want it on my 2019 Longhorn but couldn't get it without it. I decided I could live with it since it did have several "real" buttons for things like climate control so I don't have to dig through menus. 2 years later, my biggest gripes are
That's accurate..... Other than heated seat/steering wheel buttons, it has buttons/knobs for every feature the 8.4" trucks have. Just a different layout. .....
Realistically many features on the truck are underutilized depending on the owner/driver........ As @BowDown wrote, it’s underutilized. ...
Added a matte screen protector to my 12" display which helped a ton with finger prints and glare. You still have times at certain sun angles, but not as bad as the gloss. I use the Auto temp control feature on my HVAC controls almost exclusively. Only time I have ever had to switch to any other mode is in freezing temps with freezing rain and wanting full defrost, and when out "playing" in the snow and trying to keep window clean as snow is flying all around completely covering every window on the truck. And of course when it's nice out and I have windows down, I turn it offI also have mixed feelings... but mostly not for the reasons listed above.
I admit I'm also concerned about the screen bricking and losing pretty much all of the truck's electronics along with it.
But, having been in the IT world since the '80s, I am that guy who loses my sh!t when there are fingerprints on my computer screens. Partially for that reason, I've avoided getting a smart phone until this past February... and I'm learning to live with it. It still drives me up the wall when I turn the truck so the sun hits the screen face just so and all of the dust and fingerprints are on full display. I'm also not a big fan of not being able to see anything when the sun gets in that zone as well. Trying to change fan modes while driving [and hitting a soft bump or something] has me changing the input source on the radio (mildly annoying) - for that reason, I miss the knobs on my 2012.
All said and done, I'm thinking I might've been better with the 8" screen (and separate HVAC controls), but seeing that monster screen in the Black Widow I first looked at reeled me in - it's just so cool!
