TruckDriver
That is great pic!Will Rebel let you cut "cookies" with rear end locked (but in 2wd) or does it think you are going too fast and unlock?
Thanks! It definitely kicked up snowballs, with a a few taps on the gas, no auto-unlocking (probably due to speedo not sensing actual motion speed)
I am jealous as my Rebel hasn't got to play in snow yet.I read on this site from someones comment that the typical way that trucks from past with 1 wheel per axle spinning when in 4wd (in super slick situation) is totally different in these high tech trucks.
I would've missed it honestly, we were stuck with closed highways and got lucky with a place to crash on the way back - I only really went to 4Lo/Locked when pulling in/out of the driveway so I could creep - other than that, 4 high w/Traction Off was a blast
If traction control left on does it make it super sure footed and stops driver from over accelerating?
Yes and almost too much - on a normal fully snowed road (like in this pic) - trac was nearly transparent as I wasn't trying to over-accel either. but when trying to sharp turn into the driveway it felt like power was 98% killed and actually unmanageable, but then again it was my first deep snow with this truck
When traction control "off" does driver have full control of throttle or does computer still get involved?
I only did the 'Step 1' Trac Off (single tap vs hold for 5-10sec) and was in 4 high most of the time; and yes, full control of the throttle though it definitely tried to correct my 4 wheel drift when turning up a street; wish I tried the press-hold traction off method.
Appreciate your comments as to how it acts in different modes as obviously you have experienced snow driving. Does the truck ever apply brakes to an individual wheel that is spinning or is it an antilock function while braking only? Thanks!!!![/QUOTE]
Glad to give my insight, I'll have to post up in the 'offroading' threads just for snow impressions. if it applied the brakes during accel, I couldn't hear - ABS when braking was also very smooth, though I only actuated it once to test it out
