- Apr 22, 2018
Replaced the stock muffler with a Magnaflow 18". You'll need a center/offset pattern to make it easiest (the only offset/offset is in a polished finish and wasn't worth the added price). Inlet is a single 3" and as mentioned in another post, outlet is now 3" (vs. dual 2.5" of previous gen).
Part # used here is 12259. Guy at the muffler shop said everything lined up easily enough and he only had to add a short extension piece to the front of the inlet.
Its been a while since I've had a vehicle with an aftermarket exhaust, so I'm not used to being able to hear anything. That being said, I'm very happy with the 18" so far - it has a nice rumble at idle in the cab, is evident during acceleration, but mutes down nicely when ambling along to a faint background hum.
I haven't ridden in it enough to give an opinion about MDS drone that some guys report with previous gen at +/- 70 MPH cruising. Will update if there is an annoying drone.
