I installed mine and the next morning, the touch would not work. It was cold so not sure if that had anything to do with it. I decided to remove it. It is not like I will drop the screen on the ground or scratch it in my pocket...
New magnaflow exhaust installed today.havent been able to test drive yet. It's raining out and I need to keep the truck dry for undercoating tomorrow.
Sent from my MI MAX 3 using Tapatalk
A little surprised you left the 4x4 Offroad sticker on there. I removed mine and it looks great!View attachment 14393 View attachment 14394 View attachment 14395 View attachment 14396
Debadged the truck and swapped out all the “permanant” badges with black ones. Installed the diamond back HD truck bed cover, best cover I have ever had on a truck well worth every penny!
This is just a muffler swap. You cut right behind the stock muffler and bolt on the new one. Easy swap.Sorry for the newb question, but is that a cutback system or just the rear (resonators) section?
Also, is a bolt-on system or does it require welding?
Where you get the brake covers?Bought it two weeks ago finally had a chance to wash it for the first time. Inch and a half wheel spacers installed brake covers installed interior LED lighting and fogs done.
I used the ones off my 4th gen. Had to Fab new tabs.Where you get the brake covers?
I'm sorry, I'm a little confused. You use the word 'cut' (implying you literally needed to cut the pipes), but then say it's a bolt-on... I assume you didn't literally cut the pipe, but rather just un-bolted the resonators?
Thank you
You have to cut the pipe directly behind the stock muffler. Then you unbolt the pipe in front of the stock muffler. When you go to install the new muffler you put a clamp on where had cut it behind the muffler. the front bolts right up to factory. If you look at the picture you will see the original stock muffler has a bolt flange on one end and is cut on the other.I'm sorry, I'm a little confused. You use the word 'cut' (implying you literally needed to cut the pipes), but then say it's a bolt-on... I assume you didn't literally cut the pipe, but rather just un-bolted the resonators?
Thank you
Here is the instruction sheet that came with it. I probably should have just posted this first before my long rambling response.I'm sorry, I'm a little confused. You use the word 'cut' (implying you literally needed to cut the pipes), but then say it's a bolt-on... I assume you didn't literally cut the pipe, but rather just un-bolted the resonators?
Thank you
This one is the 14 in muffler. My first impressions are It is very mild sounding. I haven't had a chance to drive with it yet. On my 4th gen ram I had the muffler delete. Which was a little too loud being I tow a camper on long trips. I think this one is perfect for me it is just a little bit above stock.I'm looking at the B2 as well.. is that the 18" or 14" muffler?
Post up your impressions on quality/sound.
The quality of the muffler and the fabrication is very good.
