HOW TO: Add 360 Surround View Camera System on 2019 - 2024
I was wondering if anyone here has installed 360 surround sound with these mirrors , which have the camera at an angle. What cvpm do I need to be able to do 360 in a 2019 Ram Limited?
Currently I have towing mirrors and I would like to keep the same towing mirror style, but I want to do 360 and I want to use the same ones but with the integrated camera.
Enviado desde mi iPhone utilizando Tapatalk
i’ve been reading and searching and reading and searching.
Is there a solution to the plastic camera mount in the mirrors when you drill them yourself? I aint paying 300 bucks for a piece of plastic.
Maybe an stl file?
Maybe an stl file?
No, someone had commissioned to have it 3D scanned. But nothing ever came out of it. This spring, I was going to try to do it myself. If I can, I will offer the STL for free and also printed versions of someone wants to buy it from me.
It i could get my hands on one of the brackets I could work on designing and printing them too.
I just purchased used mirrors to complete my install, but here is the part # , 68460977AA
Expensive, but if you really want to do this mod…purchase this part, or do like I did. I found used mirrors online that didn’t work, removed the brackets from them and installed them in my good mirrors. A little bit more of a hassle, but it’s pretty easy.
what's the approximate cost of parts (new) if one were to do this mod to their 2025+ 1500??
Unknown right now. Adding this on a 2025+ will be very different than adding it to a 2019-2024. I kind of have it on the back burner to figure out, but there are harness connectors that are involved that aren’t common or available to buy, so adding the missing wiring and camera cables is going to be a big hurdle. Then there’s the difficulty and higher expense of using alfaobd to do the programming on the 2025+.
ok I just want to give a huge shout out to @Jimmy07 for answering many questions and for his assistance with my install everything works and looks good thank you
on to the next project
Im in the middle of the project. I have a 2022 1500 rebel with a uconnect 12 radio. I am stuck on the rear camera. I know I have to swap out the camera from the backup to the 360, however I can not find where the rear camera line terminates in the cab. It is not in the back of the unconnect radio? Anyone run into this? Do I just need to find it and plug it into the cvpm? As far as I can tell theres no connection into the radio
If you have the CVPM, that would be located on the bottom right side of the passenger side footwell. You have to remove the trim piece to access it.
thanks I found it it was located behind the silver shielding behind the uconnect
I installed those mirrors on my '22 Rebel when i initially did my 360. I was able to get everything(running lights AND signals, small white reverse lights etc) to work with the help of these forums. I have since changed it to the non-towing style mirrors w/ 360. I'm not sure about a 2019, but on my '22 both types of mirrors worked with the same CVPM, just made pertinent Alpha changes and re-calibrated them.
Question I just did the same. I have. a22 rebel and Chad out to the towing mirrors and the camera calibrated fine but how did you get the small white reverse lights working? Is there a setting in AlphaOBD?
I just worked through this and had some help from some other members. See the end of this thread...
Post in thread 'Any news yet on power fold for Tow Mirrors?' Any news yet on power fold for Tow Mirrors?
