Android Auto issue
I am experiencing a similar issue. Sometimes my android auto works right. Sometimes it thinks I'm in Tokyo. I live in Virginia. Sometimes driving and the AA starts out working right it will start jumping locations and start trying to continuously redirect me, telling me to make a uturn and go the other way or to turn on roads I shouldn't turn, etc. When I am out of the truck my phone is good. As soon as I get in and pair to the truck it gonna think I'm in Tokyo again. I bought the truck in April 2023 and everything worked fine until somewhere around November 2025. Initially I thought my phone might be the problem so I traded my Google pixel 7 pro in for a pixel 10 pro XL. But the issue persists.
Hi there, thanks for bringing this to our attention. Please contact our UConnect team directly at (877)-855-8400 for support with your Android Auto concerns.
Diamond
Ram Cares
Hi everyone! If any of you are experiencing Android Auto related concerns, please tag us or reach out directly. Our team is more than willing to see how we can best assist in resolving this right away.
Chris,
Ram Cares
Hi, I'm having Android auto connection issues with my 2022 Ram 1500. I've tried soft resets and resetting the Bluetooth connections but it is still inconsistent. I just deleted my AA app and will reinstall to see if that helps. Is there anything else aside from a hard reset that you recommend?
Having the same issue with mine
Having the same issue, bought my RAM 2500 new last week...android auto was fine until today. It doesn't even show up on the bottom of the screen like it used to. I have unpaired, re-paired, deleted, added multiple times...nothing works. The android auto icon shows up when the apps are displayed...but nothing happens when you touch it?
now the android auto will not work
I've noticed this and have had to unlock my phone for AA to pop up. Try unlocking your phone and allowing it access if it asks.
Chris,
Ram Cares
Hello. I am the happy owner of a 26 Rebel. I've had it a little over 2 weeks now. I initially had issues getting the phone paired. I am pretty good with tech and it took a few tries to get the pairing to go through. Initially, it kept giving me only phone bluetooth pairing and would not allow any Android Auto connection. The manager showed the AA icon, but nothing would happen when I hit it. As I said above, I eventually got it to work properly with a few tries.
Since then, maybe about 20% of the time, I'll get only the phone option and the system will not allow AA connection. Similar to the initial setup problems that I had, the AA icon is in the manager screen, but is unresponsive. When this happens, I get the big pop-up connection error window repeatedly. Luckily, when I turn the truck off and it usually reconnects just fine.
Hi there, please contact our UConnect team directly at (877)-855-8400 regarding your Android Auto concerns.
Diamond
Ram Cares
Ramcare doesn’t care. They’re gonna tell you to do soft and hard resets, then tell you to go to dealer and pound sand.
but that number ramcare posted is for uconnect.
Correct, as our UConnect team assists with Android Auto as well.
Diamond
Ram Cares
I have a 2019 Big Horn and a new Pixel 10 Pro XL. The phone has to be unlocked for it to connect with Android Auto. Every once in a while I get the connection error or device unsupported but I just unplug it and plug it back in. It is important, at least for me to make sure the apps are up to date on the phone. I have the auto update turned off on the phone. The other morning the music from Pandora and Amazon Music would skip like a record. One of the android update apps was waiting on a download. Once I did that it was fine. I am uconnect 4 I believe but it mostly works without issue. It does take some patience and over the last 7 years of owning my truck I have had to do all kinds of resets on the uconnect, but so far its been fantastic for the last 3.
Is it the truck or your phone?
I lost Android Auto functionality after an update (but not immediately). Wife's phone worked in the Ram, my phone wouldn't work in her Honda. I tried resetting Uconnect several times, deleting and re-adding the phone, resetting the phone, etc. I toggled both the wi-fi and Bluetooth off on the phone and, viola. It started working again.
Sad, but true. I posted in the forum for issues I've had with mine. No response from Ramcares. Called Uconnect and they said dealer had to flash it. Took to dealer and they said it operates as normal. So I assume losing GPS, not being able to talk to people unless I disconnect my phone, and AA or Car Play not working every time during the first drive is normal. Dealer can't duplicate but it it sit on their lot for two weeks waiting on a part that they never had to install, did an oil change and the oil plug flew out on the highway two days later. Vehicle may be good but we have horrible services centers in my area.
Hi there, we don't currently see any private messages from you. Feel free to resend or reach back out for support.
Diamond
Ram Cares
Diamond
Ram Cares
You can’t do anything so don’t waste peoples time
