Well few progress today.
The new version MOLLE Panel received and test fitted. Compare to the 6x6 universal panel, the Ram truck fitment adds another 2.5 column of MOLLE slots.
Bracket is trimmed down to the minimum to not intrude MOLLE slots, but there is still a bit of overlapping due to manufacturing constraints.
Plenty of clearance between the panel and the console surface, enough to fit in an open end wrench.
Install can be a bit difficult, as I am using nylon insert nuts to prevent vibration from high speed runs knocking the nuts loose. I may switch over to serrated nut plus threadlocker just to make life easier.
Another thing I am doing is building an adapter plate for wireless charger for the stock phone location. Allow me to explain:
If I have to describe what stock wireless charger is... all I can say is it sucks and outdated. It uses 2019 wireless charging protocol and technology, so it is very slow. When using your phone for navigation and playing music, it produces a lot of heat and minimal charging capability. In the past 10 years, we've seen wireless charging speed go from 5W (barely enough) to current 15-30w (3-6 times faster), and the technology is evolving.
What is precisely why I didn't pick the stock wireless charger when I ordered the truck: charging technology evolve every few years, and I'd like to be able to update my charger accordingly.
Previously (well, currently), I am attaching a wireless charger to the rubber backing pad on the truck side via 3M VHB and velcro so I can swap the charger out easily. However, 3M VHB does not bond to rubber well, especially when the ambient temperature gets hot. During summer, I always come back to the truck to find my charger not properly seated due to VHB not sticking.
To remedy that, an adapter is developed. Goal is to stick the VHB to the adapter plate to prevent failure from ambient heat, while still have enough clearance for charger and phone.
Currently, I am using an Anker wireless charging puck that has a contoured back. It is thicker than the charging pad I was using before (switched it out due to outdated protocol), and attached to the 110v brick plugged into the stock inverter.
And it works well!
Just a few things that I need to improve and this will be good to go, primarily the bend distance, grip, and length.
