RedFred
- Jul 6, 2022
They measured the oil that came out with me and put the same oil back in. They had a huge jug with measurements on the side that they used to catch the oil. I was inside the shop and watched the whole process as they tried to prove to me they put the correct amount of oil in it. They didn't discard the oil, they just put it back in the motor after. So 100% the truck stating to add 2 quarts was incorrect. There was no trickery or slight of hand. The owner of the place said let's go see what's going on and told me I can come inside and watch to make sure nothing funny was going on. After they put the oil back in the second time, truck was still saying oil level low and to add 2 quarts. Only later that day, when I reset oil life monitor while at a gas station, did the warning lights and message go away and oil level reset to show all was well.I'd says it's more likely the original oil change, the tech only out in 5 qts, and not seven, so it was actually low. Since I doubt you measured the oil that drained out, you will never really know, and can only speculate.
