Miss fire update for 2025 ,1500
PGH412
Does anyone have updated info pertaining to the Check Engine Light indicating Misfire?
I’ve had it in to dealership several times only to be cleared and told they are working on a fix. Thank God I only live 2 miles from the dealership. Been in no less than a dozen times. Very frustrated.
Any info would help.
Thanks
Thanks
I was getting the CEL one to two time per week since picking my truck up in March. On a whim, after reading a post on here, I decided to try running 93 octane. The light shut off within 24 hours and has not come back on. It's been three weeks. The truck runs better and I'm getting better mileage.
Stellantis still needs to provide a solution but this seems to have cured it, for now.
P0300 2025 1500 RAM ETORQ . I WAS TOLD IT WAS A COMPUTER ISSUE AT 700 MILES. VERY ANNOYED
Same issue P0300 at less than 500 miles.Dealer said it was flashed before I purchased 2025 1500 3.6 etorque. That was 5/6/25 when I took it to dealer. Was told when Ram finds a new solution dealer will call me. Ram care was no help. CEL comes on for about 3 days then off for 3-8 days and repeat. Trying 93 octane tank this week. Not happy with all the phone tag so far with dealer and Ram.
I have ran lower than 93 octane on my truck with no issue but it was never a full tank of it. I know, paying more for the gas sucks but once in a while I want to pay less. Never had the misfire or CEL either. I say all this to say, mix the tank if you want once in a while but try to stay with 93 for the most part.
So 93 fuel did not prevent CEL from returning for my truck. Not sure where this is headed but I do not have a good feeling about it being resolved.
I spoke with the service manager yesterday and he assured me that Ram must fix this and that it is a false misfire being triggered on cold start up. He is still waiting for the software update after several months. Meanwhile Ram Care has offered me some oil changes and tire rotations for my troubles. Hopefully this will be resolved soon for all of us.
I bought my truck in Oct. 2024. Had CEL within 3 days of owning it. Has been persistent ever since. Going in the Dealership Tuesday for 4th time. After this, I intend to pursue a lemon law claim. Additionally, my truck gets HORRENDOUS gas mileage. 13-15 mpg.
My feeling is there’s a bad batch of something that’s causing this. That’s why only some trucks are affected. I’m not fond of a software fix because it’s masking a problem. Also who knows what the long term effects are
CEL was off for over 3 weeks , turned back on today. I think I am going to call the dealer and make an appointment again. I have been patient and nothing is being done. May have to call a lemon law attorney as well.
8/20/25 truck went to dealer service dept. I only made the appointment so that I would have an ongoing record of the problem in case I needed to pursue arbitration or lemon law. When I got there, I was told a fix came out a month ago approximately. I wasn’t happy that I was never called like I was told I would be when a fix from Stelantis Ram was available. So my PCM software was updated from an AJ to an AK part number.
So far the check engine light has not come back on, but it has only been a few days and in the past, it has been off as long as 3 1/2 weeks so only time will tell. I was told that this will fix the problem I will keep my fingers crossed, but I won’t hold my breath. Hope this helps someone else.
So after 4 1/2 weeks, yesterday, the check engine light came back on. PO300 same random misfire code. obviously ram does not have a fix for this. The so-called fixes that have been done so far to the software are only temporary.
Same issue for me on my 3 week old 25 1500 tradesman 3.6. Did they fix yours? This sucks bad.
So I can’t say for sure that they fixed it. However, since the last flash at the end of August, the light has only come on one time for about a day and a half. I still half expect the check engine light to come on every time I start it but so far it has not . when I took it back to the dealer after the last time , there was no history in the computer that it had come on .
Mine came on at 1708 miles in the morning. Key would not remote start for second cycle. Scanned myself found P0300. Cleared code and it came back at 1836 miles. Same circumstances. Second cycle remote start failed. I knew it was going to be on again. I drove to the dealer... skipped my coffee run. They reprogrammed it. I have scanned the truck twice since and found p0300 pending but doesnt become current. Dash doesn't light up. I have 3100 miles now. Still no current hard faults causing the check engine light to come on. I have not scanned it to check if it's pending. Ram also said a fix should be out in November. Some states require emissions testing for state inspection. The im monitors need to be complete. And a pending p0300 would fail that test. I didn't spend enough money on my new vehicle. I should expect it to have problems. I like lemonade. I like cardboard drinking straws and milkshakes you can't drink. Going to bed now so I can go to work to feed the people that don't. Keep me posted.
Hello All.
Can any of you experiencing the P300 misfire code actually feel a misfire at idle or any other speed? Or does it seem like more of a false CEL signal?
Hello All.
I did not feel a misfire at all. False alarm I was told I believe it happens within seconds of starting I have not had the random misfire check engine light come on since last September. So apparently the last software fix worked.
So a little while ago, I got out of work started the truck , about 30 seconds later the check engine light came on. This hasn’t happened since last September I believe possibly August. I came home., Read the code , PO300 random misfire same as before. I thought it was fixed guess not.
