BRASS OR STAINLESS STEEL ZERK FITTINGS? THANK YOU 🤪
Installed some parts from a Ram 1500 limited steering wheel, cup holder, glove box and new door panels all look amazing no issues great upgrades love my truck
Be careful with the top portion of door panels they have the same issue as the limited dash peeling and bubling
The ones I bought were 19-24, the attachment points are entireley different tha the 25+
2025
2019-2024
Attachment points are completley different, I bought some DM Red 2019-2024 caps, took mine off then tried to install the new ones then releasied they were completley different. The ordereing guide said they didnt fit but I thought that was a mistake due to the 25 parts being new. I wish they did fit but they arent even close.
Part number is 2019-2024 mirror cap with the turn signal,
Hmm I could be wrong. I just remember I followed a 2020 YouTube how too and it was spot on. Like I said only difference is the guts didn’t allow me to reach the final clip because of the design change. But the cap itself seemed the same as theirs. Oh well.
I'm guessing you replaced yours with black mirror caps. Black ones are available for 25+ on the night edition package but there's no more body color caps for 25+.
Duplicolor makes an aerosol PRV (delmonico red), I'm going to buy that and some primer caps an paint them myself
Right side painted chrome left side factory. I'll do another coat tomorrow... 🤪
I'm hoping with the combination of new leds and a little more light reflection the output will be slightly improved.
This is the kind of stuff you do when you get old 🧓 😵‍💫
Yup I went diamond black on the mirrors and the upper grille trim piece. Discovering I can’t get the lower portion of the grille without replacing/ using an entire doner grille. So I’m going to have that piece and the bottom grille/fog light surrounds vinyl wrapped.
Well I also started it for the first time in like a month. We have a beater we drive this year in the michigan winter. Wife works from home and im retired from the Army. I put the gas pedal all the way down and primed the engine for oil and she fired right up.
Pulled power running boards and installed Rough Country boards. Bought the 2020 with boards playing games. Not dealing with them in the salt belt.
Located air suspension air intake and added a Airbrake antifreeze and conditioner. Thinking next time I do it, I will add a T and line with a cap, so I don't have to pull filter off.
Yes it is a closed system, but there is a fresh air intake behind Right taillight.
So you opened up a sealed system to add airbrake antifreeze? Which allowed moisture to enter the system.
You couldn't add it with a closed system. What's your problem? 🤪 🤪 🤣
Air brake anti-freeze is a thing but I'm not sure what we are really talking about to be honest with you 😵‍💫
Installed Lasfit floor mats. Initially didn’t really like that the outer edges covered the Ram sill plates, but after consideration I think I’m ok with it for winter use.
Air bags are not air brakes, and yes I know there is air brake antifreeze.
The factory airbags are a sealed system. Unless he has aftermarket air bags.
