- Apr 11, 2019
Alright, here’s all the info on how to use alfaobd on these 2025+ 1500’s. For those of you who are familiar with using it on previous Rams, Jeeps, Dodges, etc, this is going to be very different, and at first seem a little overwhelming.
The modules (ECUs) in these 2025 trucks use a proxi configuration, which isn’t anything new (Jeep Cherokees, Promasters, Darts have used it for years). This means that pretty much any module you replace or add, or any change to the BCM configuration, you have to perform a proxi alignment afterwards. The proxi alignment basically tells all the modules what the vehicle configuration is by “aligning” them all. A telltale sign that a module is not aligned on the vehicle is a flashing odometer.
In a nutshell, there’s three steps to making any changes with alfaobd:
1- Unlock the security gateway
2- Make the changes with alfaobd
3- Perform the proxi alignment (alfaobd can’t do this)
Unfortunately, the dealership is going to be the most practical option for most people for getting the proxi alignment done. So, realistically, you should make an appointment with the dealership for that first, then install parts and make the alfaobd changes closer to your appointment date.
UNLOCKING THE SECURITY GATEWAY
Unlike the gateway on previous Rams and other vehicles, there is no way to physically bypass this gateway via wiring or bypass blocks. You have to unlock the gateway using a scan tool that is capable of FCA’s AutoAuth gateway unlock service. The scan tool doesn’t permanently unlock the gateway, it only unlocks it for the diagnostic session while the tool is connected to the vehicle. This means that to use alfaobd with the gateway unlocked, you need two devices plugged into the OBD port at the same time, so you’ll need an OBD splitter.
Things you’ll need to unlock the gateway:
1- OBD splitter- Amazon.com
2a- Set up an AutoAuth account- AutoAuth
2b- Buy an AutoAuth subscription ($50/yr). This is for a one year subscription to unlock the gateway on an unlimited amount of VINs an unlimited amount of times. You can register up to 5 scan tools to it.
3a- Xtool Anyscan A30M scan tool- Amazon.com
This is the cheapest tool that I’ve used that was able to keep the gateway unlocked while alfaobd is connected to the truck.
I can verify that Topdon Topscan can’t do it, and Launch X431 Elite can’t do it.
If you already own a scan tool that utilizes AutoAuth, I’ll leave a note at the end of this gateway unlock section on how to verify it is keeping the gateway unlocked while connected to alfaobd.
3b- Anyscan app for android or iPhone. This is the diagnostic app that interfaces with the Xtool.
3c- Register the Xtool serial number to your AutoAuth account so it’s ready to use for unlocking the gateway.
