So what oil was being used in the engine these parts came from? That info is not disclosed in the report.
Also, that report is from 2018, so doesn't cover the current Hemi with revised lifters
I hope you’re right, and along with this the 33 gal fuel tank. I no longer see the fuel tank as an option.At the moment... neither. Wait for the 6.4 hemi, we all know its coming soon.
I thought the 33 gallon tank was standard nowI hope you’re right, and along with this the 33 gal fuel tank. I no longer see the fuel tank as an option.
26 gal is standard and 33 gal option is no longer on the website build. I'm not towing 7k# much over 200 miles with the standard 26 gal tank.I thought the 33 gallon tank was standard now
Although I believe you, I don’t see 33 gal tank listed in the specs for any of the models on the Ram website and looking at 2026 Laramie specifically. Looked at a 2026 Laramie window sticker and it’s not listed there either.33 gallon is optional on warlock up. Standard on RHO up.
Everything below the warlock is 26 gallon
Weird. Just looked and I see the 33 gallon tank listed as a $445 option on the 2026 Laramie 4x2, but not the 4x4.Although I believe you, I don’t see 33 gal tank listed in the specs for any of the models on the Ram website and looking at 2026 Laramie specifically. Looked at a 2026 Laramie window sticker and it’s not listed there either.
Yes, I’m looking at Laramie 4x4 and 33 gal not listed. Thanks for the heads upWeird. Just looked and I see the 33 gallon tank listed as a $445 option on the 2026 Laramie 4x2, but not the 4x4.
Ram really needs to do better on their site.
I was honestly considering this but 5.0 F150 has a wet belt now which looks to be a nightmare. Went with the 2026 Rebel Hurricane and happy so farThird choice...5.0 F150![]()
I was mostly making a joke with that post...mostly.I was honestly considering this but 5.0 F150 has a wet belt now which looks to be a nightmare. Went with the 2026 Rebel Hurricane and happy so far
You mean on the oil pump?I was honestly considering this but 5.0 F150 has a wet belt now which looks to be a nightmare. Went with the 2026 Rebel Hurricane and happy so far
2004 Hemi only had 345 HP, I had one in a Durango and the 2011 Hemi 390 hp that replaced it was much stronger for towing. My 2022 Hemi is more of the same for towing. I vote HemiI've had both the 2004 Hemi and now have a 2025 Hurricane SO. I would go with the Hurricane all day long! Way better, more power, smoother and quicker.
Horsepower is a sales gimmick, torque is what does the work. The SO hurricane has 469 lb ft of torque vs the HEMI @ 410. That's a 15% increase that you can definitely feel and it comes in at a lower RPM.
