Same, same, and same.I have a new 25 1500 with the standard output Hurricane and couldn’t be happier. Just about to hit 11k.
Brand new 25 Laramie… 4k miles…. 9 trips to dealer to attempt to fix multiple issues… so happy and pleased that I contacted an attorney to help me share my enthusiasm with FCA….
Dead battery is the main problem. Tranny is another issue. When I drove it regularly, I had to bring a jump box everywhere lol. Took it in multiple times and every time the batteries would pass their test lol. They finally replaced the aux battery and it still dies lol. JUNK !!!!!What are the issues?
Actually just got the truck back today from the IPC recall (B4C)… after being told by a dealership that the code they pulled… for a faulty IPC.. had no fix lol.
LOL. That makes my '22 a Nused truck. It is nice compared to most used vehicles I have bought. Good description.... a Nused (new to me - previously owned)
You probably need a recall or two. There is an ABS software update needed on my '22. So far we both seem to have dodged the rear window leak and cracked exhaust manifold. Do not know if you have eTorque, I do. So far, so good. Really is a nice truck at a good price.View attachment 209226
am i happy with my truck? most of the time yes. here's a full list:
Now the part where I am not 100% happy with the truck:
- Truck: 2022 1500 Rebel V8 ordered through Mark Dodge
- Currently at 50k miles
- Reliability
- Never had issue with the truck. Truck never saw dealership service department since delivery. I do my own service at 5k mark and driveline & transmission at 50k mark (early)
- No drivetrain issue, no driveline issue, no transmission issue, no electrical issue aside from the 12V starter battery that went recently due to age.
- With TWO additional power systems (1 Victron DC-DC charger in the cab charging my Ecoflow Delta 2 + add-on battery for fridge and USB charging, and 1 Renogy 50A DC-DC w/ MPPT in the camper for a 100AH LiFEPO4 for camper lights, diesel heater, laptop, and always on Starlink Mini) plus the LP9s, XL Racers, 4 S2s, never ran into issue where I drew more voltage than the truck can handle.
- No ball joint popping out, no axle issue - this is probably because I did everything correctly and not exceed suspension geometry.
- Performance
- 5.7L V8 with ZF 8spd is a good combo, delivering plenty of power when needed while returning steller fuel economy, even with over 800lb of constant weight.
- 4WD works great. Never ran into an obstacle on the trail where I couldn't make it. But again, I know my limits and the truck's limit, so I don't go do things that the truck is not capable of. And yet, the truck still surprises me with its offroading capabilities every now and then when crawling.
- Honestly, I never understand why people are chasing "speed" with this truck. Buy a sports car if going fast on pavement is a priority.
- Drivability
- Drivers perfectly for a daily with stock suspension. Can't comment on offroad driving because I never took stock suspension off pavement before upgrading. Yes, I swapped suspension at 400 miles because I knew what I wanted and ordered the suspension package right after ordering the truck.
- IFS system is pretty good for on pavement and long distance driving as is. Nothing to complain about.
- Comfort
- Seats are comfortable as is, though I added some seat risers just because I was bored and got money to spend. But still, with stock seat I could drive for 6+ hours non-stop.
Bottom line:
- IFS
- Yes, IFS is a double edged sword. It's great for long drives, but does not have an edge of solid front axle when off pavement.
- To step up the suspension even more, the only option I have is long travel. However, with solid front axle, I can just throw in some 3.0" shocks and springs, truss the axle, add some brackets for long arms, and call it a day. Much less work involved.
- Crawling capability and ground clearance is not as great with IFS.
- Ground clearance
- Truck is long but ground clearance is not as high. The approach, breakover, and departure angles are all less than the 4Runner I built before this due to... length.
- Aftermarket support
- This one is gonna touch a lot of nerve. Unlike Toyotas or HD (2500/ 3500) the Ram 1500 DT platform is absolute terrible when it comes to aftermarket support for legit things. This is because there's simply not enough demand for these high end legit items because the community is all about doing things as cheap as possible. On other platforms where communities are very supportive and drive demand for LT kits, portal axles, bumpers, lighting packages, interior organization and mounts, etc, legit aftermarket support usually come up with things shortly (within 6 months) of vehicle being released. Not the DT. Even when asked, the response is always "it's in the development" or "truth is, there's not enough demand for us to make it to turn profit." Well, they aren't wrong about it.
- If you take care of your truck, your truck will take care of you if you choose the established powerplant. If you choose the new powerplant, well good luck.
- Do your services regularly and early.
- Don't do mickey mouse things.
