Replacement shock absorbers on a 4-corner air-suspension Ram.
Pretty sure alfa OBD has the ability to pump down the bags without dumping all the gas. What are your plans for recharging the vented nitrogen?
Asking because I feel that this coming up for me in the not so distant future.
Yeah... I didn't have the alfa OBD tool... so that would have been smarter. As of right now... I'm going to see if it gives me any issues. I've heard the air compressor on the truck uses ambient air to add pressure as needed... if this is the case... then filling with pure nitrogen seems like a wasted effort... if it isn't the case... I'll probably head over to the dealership and have the purge and recharge the nitrogen. I generally drive in Aero mode everywhere I go... Yesterday, after getting everything put back together, I took it for a drive... pumped it up to "normal" height... and everything seemed normal... I tried to go to Off-Road 1... and it gave me a message that it couldn't perform the action (I don't remember the exact message... but something like cannot perform action at this time)... then I tried to lower it to Aero and it gave me a message of suspension system needed to cool, please wait (I've read it's a safety feature on the compressor).... this morning I was driving around in "normal" mode and put it in off-road 1 for a minute... and then back to normal... no error messages to speak of. As I said... I typically leave it in aero mode most of the time, unless there is deep snow or some other reason to use the other modes. If it doesn't give me errors... I'll probably drive it another 80,000 miles... if I get a feeling that the system isn't working correctly, I'll probably take it in for professional help.
Okay... so now the cautionary tale. Such is my life.
I was driving to work this morning and the truck started in Normal... as I got onto the interstate and got up to speed... it dropped back to Aero mode... then when I exited the Interstate... it raised back to Normal. I was driving on a stretch of road that was under construction and in an area where they stripped the payment down several inches, but created little "ramps" to get onto the bridges and overpasses. These transition ramps are pretty abrupt and I hit one kind of hard. Then my dash dinged and there was a message to "service air suspension immediately".
I limped my truck home from work... (worst ride ever)... and discovered that the front passenger side air bag had popped. My assumption is that I must have twisted it slightly when I was aligning the strut with the lower control arm bracket... this twisting internally caused stress and strained the air bag and hitting the massive bump in the road was just too much.
So now I'm ordering the factory replacement struts (whole airbag assembly... why is the left side $16 cheaper than the right side?)... and I have some "gently used" Bilsteins for the front if anyone wants them on the cheap. :P
Thanks for the pics. Was curious if Mopar had a different part number for the shock inside the airbag but suspected they wouldn't. Talked to the parts department at a dealer a few days ago to get the rear shock part number you posted there (68262591AC) and asked them the difference between that and the 68262590ACs, and of course they didn't know anything except that the 2591s are for the air suspension. Buddy offered me a set of basically new 2590s for free so that's why I was curious, but my application is essentially the same as yours (all highway and no offroad) so probably going with the 4600s.
Hey, just curious. Did you try the 2590s and how do they feel? I have a line on a pair as well but I'd have to buy them first. Hoping to save myself a few bucks if they won't work.
Cheers!
So... I was kind of in a pinch (timing wise)... so I ordered the factory replacement front airbag assemblies from the dealership... ordered before 4pm and they arrived at my local dealership before 9am the next day. I probably could have gotten the parts cheaper just about anywhere else, but not delivered that quickly. Re-installing the complete assembly was pretty straight forward and took me about an hour and half to do both sides.
After everything was buttoned up, I started the truck. The air suspension lift/lower switch on the lower console was blinking... and if I tried to adjust the height... it just said desired height cannot be achieved... so I drove it around the block... and the ride was just as bad as when the front air bag was blown out. So I parked it in the garage and I noticed the front end raise a little bit. Progress. I let the truck sit for a little while and then went for another drive. Now the truck has reached "Aero" mode... and the ride is much much better. But when tried to adjust the height, I still got the error of height cannot be achieved... and then "air suspension system needs to cool, please wait"... so I parked it and went into the house.
The next morning... I started it up... no blinking lights of any sort... pressed the button to raise it to "Normal"... and it did it without complaining. I drove to work, and going down the interstate, the truck never self-lowered into "Aero" mode, but the ride was much better.
During lunch, I went out, started it up... manually put it to Offroad 1, then Offroad 2... than back to "Normal"... no issues to speak of.
Then on the drive home... when I got it up to highway speeds... the truck automatically lowered into "Aero" mode... then back to normal when exiting the interstate.
So far, so good.
Well, all in all, I just found my next project for my recent-to-me 2021 Longhorn with air suspension. It rides relatively nicely (almost like a Cadillac) while my actual Cadillac v-series doesn't. It's part of the reason I purchased this thing, the cush ride! It's nice but it is 109k mile nice.
This seems like the PERFECT project, using 4600s. I'm sure I'll tow occasionally, and occasionally see a gravelly road, but it's a street queen for the 99.9% part and my daily, I want CUSH!!! I got the V for the sporty stuff (despite having a Hellwig rear bar on the way).
Looking forward to getting further into this in the near future.
It appears that the Rebel shock extends another half inch in rebound.
So, i was thinking about this and have a question here. Usually, when a shock extends further out like this then the compressed length is often longer. This would result in changes to the maximum compression travel available on the front end and COULD mean hitting the bump stop more often, if there is one.
I ask becasue I ran down the mental rabbit hole of changing ride height in the computer to accomodate this and that led to AlfaOBD and how that works and blah. . . .
So, the question; are these 4600's longer when fully compressed or the same length as the stockers? Are you having any issue bottoming out slightly more on large bumps/dips? My stock 2021 with 110k occassionally does on bad roads in the bay area and I'd really like to avoid increasing that at all.
M
No special toools required but the more tools you have, the better chance of finding one that will work better than others. For instance, E.Hands used a couple screw drivers to compress and remove the snap ring in the top. I had several different prybars to choose from.
The air fitting in the top is a common fitting where you push to release. The the fitting itself just threads out.
Hey OCD,
So you’re a year on now.
Any issues with compatibility with stock air ride?
See my above posts questioning the slightly longer length… any issue with increased bottoming out?
Would you do it again?
I haven't experienced any issues with my setup at all. I'm at 146k miles now so roughly 25k miles since I replaced the shocks.
Can't speak to the extra length but I doubt it matters.
Well, what did she say? JK
It's am minimal difference. On some applications, 10mm is huge, others, an inch isn't noticeable. Glad to hear this is an upgrade path here. Wish we could find these aftermarket.
In for any info or pics (and to save the thread. 2019 limited with 95k miles. Ride is really suffering right now especially with the frost heaves in the northeast right now
I wish that I had taken more pictures of that, as I too am still curious about that as well.
On the passenger's side that I did first, I undid the factory SS clamp on the accordion boot, only to realize that it wasn't really necessary.
The accordion boot appears to just be a dust cover. It doesn't appear robust enough to retain any significant amount of air pressure.
Looking up inside of the cavity exposed by removing the shock, I could see what looked like a steel surface that would brace itself on the top of the shock body. I think that this is what the bottom of the air bag pushes on.
Like the inverse of this:
It is hard to imagine that the weight of the truck is supported by the snap ring. And the stamped steel part that rests on it seems to be just something that the accordion dust boot attaches to.
Although that is clearly what the coil spring uses to support the trucks weight. As seen below:
Did you need any other parts like crimp rings etc for the air bags?
