Ram Rebel X with Carli Commuter and other mods
I just stuck with the stock UCA's for now knowing I can always add them if needed. Rightnow for my use I don't feel they are needed. So just the basic Carli Commuter Kit
My 2nd smart cap. I especially like it when having the multi flex tailgate as you can open the tailgate without having to lift the topper rear door up so accessing the Truck vault drawers is easy if that is all I need. Make sure to get the lock covers as they did not have them when I had my first one and the door lock would ice up in the back from blowing snow
Timbergrove airbags go on next week along with a warn quick connect for a rear winch in the receiver
Hi to all !
I have two questions for the Rebel X 2025 owners:
1) owner manual consist only in "owner handbook", "quick start guide" and "consumer information guide" ?
and also
2) is it normal that the yellow sign "axle locked" is always on, in every mode (2wd-4Auto-4High ecc..) ? ....see photo.
The first question is to understand from the owner's manual, but I haven't found anything about the off-road features of the Rebel X 2025 version.
Thanks everyone for the replies.
Hi to all !
and also
in 2wd it shouldn't show as locked.
@boogielander , I think the same thing too.
And also, shouldn't the differential lock control (which is unique) lock only the rear?
Instead, I think this truck also has a front lock... maybe for the X version of the Rebel only.....
Today I'll ask to the dealer for clarification (I picked up the truck yesterday).
Rebel X my2025 - 3.0 SO
Inviato dal mio SM-F766B utilizzando Tapatalk
no rebel x doesn't have front lock.
none of the 1500s have front lock.
front lock is only available on 2500 power wagon.
and you're right the lock should be in the rear... i think.
i haven't really paid attention to mine (i have a 22 so no digital dash like yours)
maybe just a glitch
@boogielander , Thanks so much for the clarification.
So if even a Rebel X RHO (if it exists...) doesn't have it, it should just be an electronics issue (perhaps a software bug).
Updates will follow
I have some news...
But I don't know if it's good or bad
It's not the front differential that is locked, but the CENTER differential.
Driving 2WD, this situation could also be normal, but I ask myself:
"If center differential were unlocked too, wouldn't the truck consume less fuel?
What about the Ram Limiteds that have a lock ? - Who knows this thing ?"
Thanks
I have some news...
Thanks
center diff locks are found on all time four wheel drive vehicles (ie, landcruisers)
if you have 2WD, there is no center diff. you only have transfer case and that is only engaged/ locked when you shift into 4WD.
if you see 4WD-Auto on your transfer case selector, that means your t-case is engaged/ disengaged via a CLUTCH type of connection when in 4WD-Auto.
@boogielander, I've read your clarifications. Thank you. They match whith mines (with Nissan Patrol, Toyota BJ, Land Rover defender).
My reasoning is that WHEN the truck is in 2WD, the center differential lock should be off (grey and NOT yellow and closed like in the photo I post here at th taken in 2WD !!).
Central Diff: LOCKED (yellow)
Rear Diff: UNLOCKED (grey)
For me in 2wd is wrong, but maybe that the wrong is me.
I don't know, I'd like to understand..... we would need a ram rebel X user (2025) to look at the off-road page on the display (in 2WD).
yeap that's exactly what i mean.
i think it's a software glitch.
I played with the settings last night. When you engage the rear locker the rear light comes on but the front one as shown never changed regardless of which 4wd setting I put it in. Would agree a software glitch or it means something none of us know.....
checked mine.
in 2wd center diff lock icon is in unlocked position.
I went back in and looked again It shows locked on the digital display but when I go to the off-road pages on the center screen it shows unlocked and responds to each transfer case change accordingly
yeap a glitch for sure.
try unplug the battery for a hard reset see if goes back normally.
This thing is another variation .... very nice !
Today (perhaps) some news...
200 Mile trip Avg 10.7 MPG (Not hand calculated but it was close before when I hand calculated so should be right in there) From 4500 Elevation to as high as 7500 and back again 80% of the time at 80MPH
35 PSI in the Timbergrove airbags
What PSI are you running in your AT3’s? I put a set on my first rebel shortly after the tire was released but wasn’t a fan of how it drove. Thinking of giving them another shot but can’t decide between those or the Terra g3s. Staying with the stock size though.
Right around 49 right now With the cold weather they will drop so I keep a touch more so I don't have to look at the alert I was running around 43
