Hellwig? Hell, yeah!
Putting the hellwig sway bar on stiffest setting, will it put strain on the end links? I been running it middle hole.
Unlikely, I had the stock links for quite a while on the stiffest setting and there weren't any signs of strain. Might be a different story off road though
Where can I find this sway bar , is there any other brands ??
I put Hellwig front and rear bars on my '25 Laramie and for front end links, Suspension Maxx urethane assemblies, all within first couple months of ownership.
The OEM parts are laughably low-grade quality in comparison to the bolt-on bars and links I replaced them with - both ride and handling qualities have exponentially improved in result. Totally worth the cost and the few driveway hours it takes to install them.
Added the Hellwig 7709 sway bar to my 2024 Limited with air suspension20251102_145409.jpg....set in middle position. All mounting holes were proper, and no kinks in the bends. Quality hammer finish. I'm heading out to Prescott AZ from San Diego next weekend. Should help on the curvy mountain roads.
Has anyone put the Hellwig on with the Eibach 2R level/lift? 7709? Or did you use other? Curious if you use the "softest" setting or started in middle what the feedback is. Also, confirming Hellwig told me 7709 is the correct part for the 25 even with ORG, but has anyone used that with the Eibach/Bilstein/Fox setups?
Ive got my 7709 sitting in the garage for sale since upgrading to the laeger one. Shoot me a pm if you want to cut a deal and join the happy hellwig owners club!
Suggest upgrading rear links with CORE4X4 while you're at it.
Added the Hellwig 7709 sway bar to my 2024 Limited with air suspensionView attachment 207522....set in middle position. All mounting holes were proper, and no kinks in the bends. Quality hammer finish. I'm heading out to Prescott AZ from San Diego next weekend. Should help on the curvy mountain roads.
How does it work with air suspension? Does it make sense? Since it actively levels itself anyway?
It works great. I did notice a difference. Air suspension controls the height, not the body roll. I pushed it hard on highway 89 up to and down from Prescott AZ and it definitely helped... and would have been even better set to firm. Traffic was light that day making for a fun run! 1763761939356.png
Here's 2 cents:
If it helps, I've run a Progress Tech 25mm and Eibach 25mm Rear sway bar with Fox PEs and Eibach Stage1..both preloaded to 2.2" lift Front and 0.75" lift Rear..and on all setups, the Tightest (inner hole) is the best for steering, handling, and body roll..especially the more lift you have.
