tonneau covers that work with the multifunction tailgate?
Can you please send me a pic of where you placed the clamps?
Hi, and sorry for late reply. I didn't see your question and haven't had a chance to take a pic. I'll try to get you one. but it works.
Hello @troymi, the clamps you have placed is that what diamondback provides you with? I am thinking of ordering the diamondback switchback, as per your pictures and your previous post, would it be safe to assume no modifications are required? Except place the clamps in the manner you have indicated? Thank you for providing the pics, Diamondback is the best option for me but the MFT model makes it tricky.
Yes,the clamps I used were the Diamondback clamps. I did not modify at all, but after a few months I added a small automotive/marine grade seal along the bed that is under the Switchback for added water resistance. I consider this a great solution if you need to use the bed open and want the best overall protection. Also, even with the Ram OEM bed lights, I still added another light under the Diamondback, it get's pretty dark in the bed.
Just got these brackets. Do I need to modify the rails as the rails toward the front won’t wit flush due one of the bolts on the bracket ?
I know this is an old thread but what are the current options for covers for Tungsten (with Ramboxes and MFT)?
Bakflip MX4 and Ram's own version of that both work with the 5.7 bed with Ramboxes. I know this because I have had both. There are several threads on this subject. If you search the forum, you will find multiple options.
Tungsten already come with a backflip soft cover. I am looking for roll-up like Sentry or Revolver.
The OEM tonneau is a soft cover. The Bakflip MX4 is not a soft cover
The Ram version is not a soft cover either.
I apologize, but I have never cared for a roll-up or revolver. I expect someone wil be along shortly with knowledge of those two for you.
Hey... I think we corresponded elsewhere... ( I had notifications set for this thread from a while ago)
For MFT + RamBoxes, there's another thread: Help finding a rambox and multi functional tailgate compatible hard tonneau cover. What is everyone else using?
I'd use the RealTruck chat to confirm - but if it were me (and assuming they're compatible) I would go with the Sentry CT or the Bak Revolver (I've seen word that they work with RamBox + MFT, but NOT MFT alone.. (I don't have RamBoxes)
I have the Sentry CT on my current truck. I had the Revolver on my last truck.
I have the Undercover Flex with Ram boxes and MFT and I love it so far. Don't have a pic available at the moment but here is a link:
How does CT compares to Revolver? I had CT on my TRX and loved it.
The Revolver has a full length lock, versus the CT has a mid-lock and rear lock (along with the velcro)
The Revolver has a rubber "contact seal" - where the CT has the velcro seal. The velcro stays down - versus the rubber contact seal tends to sit flat if you roll it up often, or in cold weather. Sometimes it takes a sunny day for it to lay back down flat.
They both have advantages...
Yes, that is the one that I purchased. My truck is a 2024 and it's a Limited Elite, not a Longhorn Limited, but I do have the MFT and the 448226 is a perfect fit.
@PatriotLonghorn , @Humphammer , @detroitm2 - sounds like each of you have the multifunction tailgate with the added braces and purchased the Bakflip MX4 from Realtruck. Based on your messages, it sounds like buying the one that says it’s compatible with the MFT does fit trucks without removing the front braces.
Is this correct?
Does this mean Bakflip modifies the mounting rails to accommodate leaving the braces in place? I haven’t looked too closely at this yet, but that’s all I can think of how they make it work. I definitely prefer that option rather than removing the braces and replacing with a different L bracket. Appreciate any insight you all can provide.
Is this correct?
I actually went with a retrax cover instead. But I ordered alternate braces in place of the OEM ones. I forget where they were from but you can search around here and probably find them. They are lower profile and don't get in the way of attaching most tonneau covers.
Is this correct?
I believe so, it worked just fine out of the box. I wasn't all that happy with it though, as the aluminum skin is really soft and didn't last up to even the mildest of hail.
Got the Extang Solid Fold 2.0 for my 2020 Ram 1500 with MFT. Installed it the other day, fits fine. Haven't checked it yet to see how dry the bed is, will have to check sometime.
Do you have pictures of the Extang on your Ram with MFT? I haven't found anything online that says it fits.
