tonneau covers that work with the multifunction tailgate?
I have a BakFlip MX4 on a 2024 Limited with the MFT. Install took maybe 30 minutes, it fits perfectly, it's very light, and about as waterproof as you are going to find. It's a bit pricy, but in the long haul well worth it.
Were you able to use the factory bed brackets up near the window, or did those have to come out?
Also have the MX4 on order.
Everything I've seen shows you have to remove them. Right on Brackets makes a replacement part that should allow you to retain the rigidity of the bed, and still be able to mount most tonneau covers.
You do not have to remove anything from the truck bed with the MX4. It is made especially for the Ram with the MFT. It is a perfect fit at least for the 2024 model. I can't speak for the older models, but I assume they are probably the same. If you are referring to the brackets in each front corner of the bed they do not have to come out.
Interesting. I was curious about that since when I ordered mine, they specifically had an option for "with MFT".
Guess I have a set of aftermarket brackets for nothing then :)
The only option they don't have is a bed with Rambox and MFT. That's what I need.
Who did you order though? I'm trying American Trucks but their site is a bit odd when it comes to w/wo MFT.
I ordered through my wholesale distributor, it's not really available to the public.
I ended up going through Real Truck as well, they 'guarantee' it's the one for the MFT. I'm hoping they are correct.
Part #:448226
Part #:448226
Yes, that is the one that I purchased. My truck is a 2024 and it's a Limited Elite, not a Longhorn Limited, but I do have the MFT and the 448226 is a perfect fit.
Alright, Here's the steps I needed to take to fit the Truxedo Sentry CT Tonneau Cover to the Ram 1500 with a multifunction tailgate:
Update: I just put a 2,300mi road trip on the truck - rain and snow. It looks like I'm all set and fixed with the Sentry CT. No issues with the cover.
Added a Truxedo Sentry CT tonneau cover with Elevate Racks and crossbars. Pretty happy with the setup.
Racks on racks! 🤩 Your whole setup looks great! I'm glad to hear that you're happy with how it came together.
I have the soft fold from the factory on my 21 Limited and it works great with the MFT.
Couldn’t you just loosen the stock brackets and slide the rails behind them and then tighten them down?? This would hold the rails in place too.
FWIW I put a Diamondback Switchback on a 2025 with MFT. Corner brackets made it impossible to put clamps as designed. I put each side close to bracket and the rear most section. Clamped down and drove 250 miles. Rain then 6” snow then thaw and car wash. 99.9% dry. Tightened 2 turns and drove another 250 miles. No issues. Amazing as advertised so far
So I installed the X15 over the weekend with the OEM brackets still in place. I did loosen them and knock them down as far as they would go. It looks the they now trim the side rails all the way up to the flat part of the rail. I did have to open up the hole in the rails so I could slide them forward just a little. Everything works . [
Can you send me a pic of how/where you put the clamps?
Can you please send me a pic of where you placed the clamps?
