.y transfer case asks for mobil 1 LT what kind of fluid is that. Does it have a weight or viscosity? Can I use something else ?
Lots of debate on this. Like was mentioned above it's Mobilfluid LT. I went with Redline MT-LV for mine. It's listed as a compatible replacement.
Just did an oil change and turned over 46k miles. As a reward to me, the passenger side door lock has crapped the bed...$250 from the dealer for the part. Ugh
Going to look at some aftermarket options.
Went down to the DMV and registered out new Tungsten. First time I registered a vehicle bought out of state that didn't have at least one error with the paperwork! You can sure tell that Mark Dodge has done this before.
Bought mine out of state also, paperwork didn't have any errors but they missed the taxes by $320. DMV said most out of state dealers don't get Texas taxes right
Well, not today, but yesterday, on the second day of us towing our travel trailer (TT)South, it went into a dealership to try and find the the reason for it once again, puking lube all over the front of the trailer and all over the truck...
The last time i went through this, it was blamed on a leaking oil filter, then the second time, it time it was the residue from the time before.
THIS TIME, it was diagnosed as a bad rear transfer case seal at the drives shaft, which I thought it was the first time back in February. It was replaced under extended warranty and off we went.
Late this afternoon when stopped to pick up a new repair part for the TT, and low and behold, much more lube coating the back of the truck and front of the transfercase!
So, once again the trip is on hold. We are in an RV park, and I'll start hitting dealerships first thing in the am seeking help..I'm now wondering if the vent tube is rusted shut..
Does anyone out there have any ideas as to what is causing this aside from moving to a differant brand truck?
ON EDIT: Well, looks like the Ram is getting a new transfercase. Should be in tomorrow!
You should definitely trade it in on a Honduh Ridgeline. Will solve all your issues.
Or, depending on the size of your TT, you may be better off stepping up to a 2500
I like the Ridgeline idea..and a 2500 may be the future, but our TT is a great size for the 1500, and has no issue pulling it, and I only run about 62mph.
Rolled over the 100,000km mark yesterday. Didn't get a pic because I was in a meeting while while on the commute.
So upset!
Well - here's to all the crap that's about to hit the fan!🍻
I understand your upset.
Went to Vancouver Island for holidays last week and this happened…
My extended warranty runs out at 160,000kms.
  • Back
