I agree hood seals up pretty good. The only thing I see this doing is sucking hot air post radiator through hood latch area.
Am I missing something here?
Gotcha thank youYes, your not seeing the scoop that goes down behind the grill. That's why it requires you to trim the shroud or leave it off.
It should be both. Ramming hot air into the motor causes a power loss.It is being sold as a 'ram' intake, not a 'cold air' intake...
Looks badass! I was just gonna post asking about Vararam! Keep us updated after you drive it around!Install was easy as can be. Took all of 45 minutes including cutting the shroud. Vararam 's install directions show leaving the shroud off but to my OCD, it doesn't look "right". Haven't really driven it to give any feedback on performance yet.
View attachment 14685View attachment 14686View attachment 14687
Glad to see those who have installed theirs found there to be an easy job.
I did. It looks like hot air from the radiater gets directed up that ramp if the shroud is left off in the front unless I'm missing something. Cutting the shroud could block that depending on how it's trimmed....but then it seems the hood seal on the front would block air. I gotta go look under my hood to see how this all fits.
