11B4X4
I just wanted to make a catch all post for some note worthy topics with my truck.
First, upon trying to put gas in my truck for the first time I learned that there was a malfunction with the fuel system. The pump would click like it was full immediately after squeezing the handle. The end result was a factory defective 33 gallon gas tank. The tank was replaced under warranty and the issue has been resolved
Moving right along....
3.5" Readylift on stock Premium 20's, wrapped in 295/65R20 Cooper Discovered STT Pro's
Some minor rubbing near full turn while driving forward, it feels like UCA rub. It's not severe enough to correct. However, it would not be ideal if you put yourself in tight places on a regular basis.
Also, Some rubbing of the wheel well while making a sharp turn in reverse. Again, not enough of an issue for corrective action, at least for me.
The truck still rides nice and smooth. The tires are pretty loud on the highway, but I don't mind. While using the Bluetooth the person on the other end can't hear any noise.
Significant drop in MPG, as expected. Pre-Lift I could achieve 21 mpg at highway speeds. Now, If I feather the throttle and work the hills I can get 14.5 MPG (Gauge Readout). Granted that has not been re-calibrated for tire size and the gauge was .5mpg optimistic prior to lift and tires. So no clue how far off it is at this point...The pictures aren't the best, but you get the idea. The side by side comparison is with another 1500 with a 6" lift on 35's
Lastly....
Rust on the rear axle. The dealership says it's normal. I feel a $53k truck should not have rust when brand spanking new. Does anyone else have these rust spots ( See photos)? I have opened a case with FCA to have it looked at and hopefully repaired and with any luck a complimentary undercoating.
So far I really like my truck. I am coming to Ram from a lifted 2006 Tacoma which I absolutely LOVED, but was ready for something new and bigger.
If you have any questions or comments let me know.
Lastly....
