Gemini located the bearing with those specific measurements. This is a non-standard, specialized bearing, most commonly used for automotive air conditioning (A/C) compressor clutches.
The bearing you're looking for has an inner race that is narrower than the outer race and is flush on one side, creating a "step" or offset on the other.
Bearing Identification
The bearing with these specifications is often referred to by its dimensions or specific part numbers rather than a standard series name (like 6203).
* Inner Diameter (ID): 17 mm
* Outer Diameter (OD): 40 mm
* Outer Race Width: 13 mm
* Inner Race Width: 10 mm
* Common Application: Automotive A/C Compressor Clutch (fits various models, including Sanden compressors)
Common Part Numbers
When searching for this bearing, using one of the following manufacturer part numbers will yield the most accurate results.
* 174013-2RS
* SC03A36LLH1 (NSK)
Where to Find It
You can typically purchase this bearing from specialized suppliers.
* Online Bearing Stores: Websites like VXB Bearings, Accurate Bearings, or other industrial suppliers often carry it if you search by the part numbers above.
* Automotive Parts Retailers: Stores like NAPA, AutoZone, or O'Reilly may stock it as an A/C clutch bearing. You may need to provide your vehicle information or the compressor model number.
* E-commerce Sites: Amazon and eBay are good sources if you search for "17x40x13/10 bearing" or "A/C Clutch Bearing 17x40".
