SGW 2025 Ram 1500 Big Horn
The issue is not with making changes. The issue happens when we need to do proxi alignment in the end. Maybe you can make changes with Alfa and do proxi alignment with official witech software but those of us that have tried with alfa haven’t been successful at getting all the modules proxi aligned after changes
I will report my findings, at least if it is successful you can go to your local dealer and offer a tech lunch to help out. :)
I tried this method this morning, as soon as you try to connect to the truck with alfaobd the SGW locks out. I can see in witech with the MX link connected all the module go red and even the MDP can no longer talk to the truck.
Ok, looks like you’ll have to go with the topdon scanner with autoauth to do the unlock.
Then when done using alfaobd, use witech alone to do the proxi alignment.
I have an Autel scan tool with autoauth subscription. It looks like the same thing is happening. I'll try again on this Wagoneer that I have this morning.
I use these tools and im able to unlock sgw and have alfa and cda6 connected simultaneously while sgw remains unlocked. I was even able to do write successfully in cda6 while having everything connected.
Amazon.com
What year model? This was on a 25DT and a 22WS
I tried this on 23WL SGW and BCM. I don’t have 25 SGW yet to try on 25 BCM since the 23 WL SGW doesn’t recognize the 25DT BCM
I ordered the Xtool adapter it will be here tomorrow. Will post with findings.
