SGW 2025 Ram 1500 Big Horn
Mission was a success boys. 25 DT 35 inch tires changed tire size using a 21 WL model in Alfa and Autel scantool to unlock SGW. Afterwards I performed the proxy alignment and all is good! Did have to reset the bcm to get configuration mismatch codes to go away.
Oh, good. And that proxi was with witech? So regular guys should be able to at least make the changes with alfaobd and autoauth, then take it to a dealer for a proxi alignment afterwards?
As far as I can tell. I used my autoauth on a MK900-BTt autel scan tool and alfa obd with obd link MX adapter. Unlocked gateway using autel then with obdlink pod hooked up to splitter made the dynamic tire size change from 2480 to 2700. Truck was pissed off. Hooked up MDP using dealer witech subscription and was able to performed proxy alignment of all modules. The PCM was showing not aligned but I reset the BCM and all was good. Also ABS initialization obviously.
