***update*** 8.4 w/nav upgrade to 12in having backup cam issue
Bubba78
There are a few threads regarding the issues after upgrading from 8.4 to 12 inch uconnect system, but I can't seem to find any concrete solutions. I am hoping to get some help, because this has to be either software/firmware, or setting. Please help!!
I have a 2021 RAM 1500 3.0 EcoDiesel (5th gen). It originally came with a uconnect 4 with NAV 8.4 inch screen. I have since upgraded the screen to 12 inch, with a compatible module (I have tried a different 12 inch screen as well), purchased on Facebook marketplace. My original screen had the grey connector, my new 12 inch screen has the black connector. So I purchased an adaptor from @Infotainment UAX UAV Uconnect 4 upgrade interface which worked perfectly. So every feature of my upgrade works flawlessly except for my backup cam. My GPS, NAV, WiFi, Android Auto, climate control, heated seats/wheel, steering wheel controls, hazzard switch etc... The only issue I have is that when I put the vehicle in reverse, the back up camera does not trigger, and when I press the button for backup camera, I get a blue screen. I do have alphaodb, and have checked, and tried many settings with no luck. I even reinstalled my original 8.4 inch module and screen to make sure that the camera, cable and connector all work properly, which they do... But the backup camera is my only hang up form a successful upgrade. I am including some images of part numbers in case anyone who can help needs to know. Thank you in advance!!
12 module, in truck now
back of 12 inch screen
Blue Screen
Working 12 inch screen
I am going to see if I can download/upload my vehicle log from alfa incase someone can review.
hoping to get some help on this one, I am pretty certain it has to be a software setting. @Jimmy07 any thoughts on this? I also noticed that when I view the Offroad pages, the screen on the far right is cut off
I figured it out, I needed to update the app version. I was LR34.2.0.. so I updated to 39.9, reverse camera now works...
So the upgrade is what worked? I’m having the same issue.
Blue Screen
you need to change they year to you truck to what ever year the radio came out of
I have a 2022 Rebel GT.. I am also looking to upgrade my 8.4 to the 12". What do I need to do to make sure it works as OEM? I have talked to the dealer, and multiple custom shops and they tell me the infotainment centers need to be programmed to the VIN to work properly. Can someone educate me on this please.
I purchased my 12in screen and used alpha obd to change the year of my truck to the year of the head unit to make it work as oem
ok, so I am looking at doing this whole process. I have a 2020 Ram Bighorn with the 8.4. My old truck had the 12" and I just cracked my screen. Any suggestions on doing this upgrade? I looked on ebay and noticed some radios say "locked". Does that mean I need to install and take to dealer?
Thanks
