mikemcfarland
Just an update. My buddy and I were able to tear into this tonight and see if we could figure out what is causing the "chirp" sounds I keep hearing. For starters, I was 100% convinced that the chirps were coming from the bushings in the upper control arms. The reason I was convinced was because I improperly greased them when we did the install. Call it a rookie mistake. Not to mention, I've been packing the bushings with grease to see if it would solve the chirps. I've since learned, grease is not a friend to bushings, there is a proper way to grease a bushing sleeve and then there was the way I did it, grease all over everything. Wrong!
We took out the upper controls and bushings, degreased everything including the mounts, applied grease correctly to the bushing sleeve and put it all back together. I even remembered to bring the castle nut spacers ReadyLift forgot to include in my original kit.Went for a test ride, same result. As disappointed as I was, we eliminated a possible source.
With my buddy hanging his head out the window, he notice that the chirps weren't coming from just the front, they were coming from the rear as well. We did not do any work on the rear. My buddy thought it could be the wheel caps so we went back to his place and removed them and went for another ride but had the same result. If I hit a good bump, we would hear a chirp. We then picked up on a pattern. After I hit a bump, the next time I applied the brakes, it would chirp again. We did this over and over and it was consistent and we both thought it could be the brakes. To test our theory, we went over the same bumps but with the brakes lightly applied and it was silent. We did this several times and it continued to be silent. Take the foot off the brake and hit a bump, the chirp is back.
In conclusion, it is the brakes. I believe the pads have some wobble to them or possibly the calipers or pistons??? Are my new heavier rims and tires a contributing factor? Hard to say and the only way to prove it would to be to put the old ones on to which I already sold the tires. I'll have to see what my dealer has to say when I take it in for it's first service. I can however say with 100% confidence, it is not the level.
greatly appreciated the time and write up @troutspinner
i had the ready left level with upper control arms done(see signiture-updated). i drove home 350 km's and was listening for your issue- heard nothing at all. the ride was great. work done by the dealer.
