Remote start not working. 2022 ram 1500 bighorn
ranny
Hello. My remote start does not work even though on Alfaobd and Jscan it shows that remote start is active. When I double click the button on the remote it honks once and that’s it. I’m not sure what it is, I’ve checked multiple forums and videos online but nothing has worked. I have a feeling it might be the key fob but it’s the one that came with the car so I’m not really sure. Please help
Have you seen this post?
Assume you know about the various vehicle parameters that can inhibit it. Also this is in the owners manual:
The following messages will display in the instrument cluster display if the vehicle fails to remote start or exits remote start prematurely:
•Remote Start Cancelled — Door Open
•Remote Start Cancelled — Hood Open
•Remote Start Cancelled — Fuel Low
•Remote Start Cancelled — System Fault
•Remote Start Disabled — Start Vehicle to Reset
I called my local dealer and they said remote start is on my truck. I’ll see if those messages come up on my dash. Thank you
I have not seen that thread but I have done those steps
Yes, there are posts on here how to add it afterwards. That link above might help, otherwise search add remote start. You can always go aftermarket with Viper Smart Start using your phone, but costs yearly. Used to be cheap, not sure now.
Should I go oem remote start or aftermarket? What’s your opinion
If you like the option to remote start from distance, aftermarket would be best and usually cheaper. IF you don't need the distance, then OEM
did you buy your truck new or used?
Shot in the dark here but you said "When I double click the button on the remote it honks once and that’s it." Do you press the lock button first and then double click the start?
check your battery voltage. if it's under 12.0 VDC, it may not remote start. my 5 year old battery read 11.6 VDC (after it sat overnight) and it will start normally, but will not remote start. once I replaced the battery, everything is good to go.
I added Start-X to my last Ram, I was very pleased with it. Easy to install and worked well
