I ordered my truck in October of 2022 and Ram was still suffering from "supply chain issues" So even though I ordered the level 2 option package with Uconn 5, I ended up with a 8.4" screen instead of the 12"
So I finally upgraded to what I should have had in the first place.
I must say, Infotainment was fantastic. Instalation was surprisingly easy and the auto programming went seamlessly.
Power folding tow mirrors are on the way!
Before
After
Sweet !
Hows the ride quality and noise level? I'm in the process of getting the exact same setup done to my 22 Limited and see these tires for very low prices. I'll be getting the 285/55/22 as well but will be adding the Revel level but happy to hear your not rubbing in stock heights!
There was no change in ride quality. I have the pressures set to 46PSI. I do hear them, as expected, but just barely. I'm sure they'll get worse as they wear... and that is also to be expected. I just hope they're not as loud a Ridge Grapplers that I had an a previous vehicle. No rubbing at full lock with this size. Thanks. Post pictures when you get them mounted!
Before
After
wow you ordered later than i did but still got hit with the supply chain issue?
i ordered June 2022 but didn't get my truck till october but i got everything I ordered with. interesting how it happened like that.
When I first ordered they predicted an April delivery date and then it showed up December 22nd. Even the dealer was quite surprised.
Maybe instead of waiting on the big screens they pushed it out with the 8".
