Rlaf75
Takes potshots
- Jul 9, 2021
Clearly it's a traction issue. Whether gravel covered roads or snow covered roads you need to alter your habits to maintain control and not out drive the conditions. Just because the speed limit is 30mph doesn't mean you should drive at 30mph if you're slipping and sliding. I don't know the grade angle of the road but tire pressure, speed and weight will play a major roll. If you get to the point of feeling unsafe I'd recommend putting it in 4hi or 4lo depending on the grade and drive accordingly
