Just spent a weekend camping on Steens Mtn in south eastern Oregon. Lots of driving on gravel roads. The main loop road up and over the mountain is a 59 mile stretch. It is a fairly decent gravel road,it is posted for 35mph speed limit and while you wouldn't want to take some of the sharper corners at that speed, plenty of it, including the hills, was quite straight and would be safe at that speed. I included a picture of the road and it can easily be navigated by small passenger cars. I've done it myself in the past in my Subaru. However, in my truck this time, I had several occasions where the back end lost traction and the truck began to sway / fish-tail on the road. It was bad enough that the ESC light in the instrument cluster flashed a couple times and was decidedly an unpleasant experience ! Happily there were no cliff edges present at the time.
I am a truck novice, this Rebel is my first truck, and I've a grand total of less than 2,500 miles driving experience ! So I'm open to any and all input as to what I'm doing wrong here!
I did notice this only happened when the road was going up a steeper grade and there was severe wash-board on the road ( which of course there generally was on the steeper sections ! )
I'm guessing that what's happening is one of the rear wheels is losing traction while the other is still gripping and pushing the truck forward. This would introduce a 'turning moment of force', right ? But since the front wheels aren't doing the same thing, the only thing that can happen is for the back end to sort of pivot side-ways. It's kind of like having rear-wheel steering when you're not expecting it !
I tried 2Hi, 4Hi and 4Auto, it happened in all those cases. Perhaps a little less so in 4Hi I think, but on at least one occasion it was bad enough in that configuration to make the ESC flash.
The only real way to avoid it was to slow down to less than 20mph on those grades. Let the truck just chug up the hill, and then it stayed firmly in control.
Is that the solution ? It just seems surprising that an "off-road capable truck" seems less capable on a gravel road than my Subaru Outback ! I feel like I must be doing something wrong !
The truck bed was not empty. I have a ~175lb roof top tent mounted on a bed rack, plus all my camping stuff in the bed. Do I need to chuck in a few 50lb chicken feed bags from the barn as well before I head out? Just kidding, but I'm thinking it must be something to do with not enough weight on the back of the truck to get traction going uphill ?
What about my tires ? I have the stock tires from the factory. I did notice the tire pressure looked on the high side. I've never added to nor removed air from the tires and I noticed they were reading from a low of 57 psi on one to a high of 66psi on another. That was while driving on a hot day. I know Overlanders often reduce air pressure when going off road, but I'm thinking that's on soft terrain not hard gravel road ?
By the way, with those tire pressures and the Rebel suspension, some of the washboard parts were terribly jarring, there were places I slowed to 15mph or less just because of the vibration.
Interested in any thoughts from the community on how I should be driving on gravel with washboard while keeping in control of the rig !
