I was always a fan of the flush look also, until I did this....
☆285/60R20 on a 20x9 with +1mm offset☆
The thread is flush to the flare edge (I added flares to my '24 Larry) and just a bit of sidewall pokes..I really like this look now!
Technically, there is 0.16" poke (0.91" poke compared to OEM wheel/tire minus the 0.75" Mopar flare).
Also, the rears have 6mm Bora spacers to match up the Front and Rear axle width..and tire poke.
First pic is pretty straight side shot, Second is slightly off angle, Third is fuller shot....
View attachment 204546View attachment 204547
Your license plat is intriguing 🙂
Haaa, yep, I don't blur my plates in photos..cause the 2A part of that plate should tell you I'm not messing around...
pew👉, pew👉
(when you live in a place named Town of Eagle🦅, you have to be patriotic🇺🇲)
When I setup my NFA gun trust, I used a $2 bill to "fund" the trust. I went to the bank and got 5 $2 bills. They coincidentally gave me bill serials that ended in 1A, 2A, 3A, 4A, 5A.
I used the 2A bill for the trust and gave the 4A and 5A bills away. I still have the 1A and 3A bills.
I haven't seen any recent pics of you borrowing "Marty" for your trips.
She's a beautiful black shepherd!
Marty's been spending time inside because her dad got a OBS Ford with a slide in and can't go most of the places we go lol
even i havne't been going out as much this year
Awhhh, now I'm cryin'😪🙂
we trying hahaha
i actually prefer it that way because with the OBS and slide in out that means no bumpy no technical trails. usually that means i get to relax lean back when i drive and most likely no air down needed lol
not today but a week ago:
used my truck to pick these up from the office. Sony overnighted the body and the lens and Amazon 2 day it the Sigma.
I kept on forgetting to post lol
i'm one 200-600mm lens short and i got all i need for wildlife and outdoor photography. maybe add a prime lens in the future. but for now these put me back at where i was before.
also trying to figure out why my window guy and my tint guy manage to kill my battery but when i tested the battery with a tester I got "battery is still good"... hmm
we trying hahaha
Ahhhh, now I'm cryin' more..I was being disingenious about the truck stuff...really just interested in how Marty is!!🤣🤣😳😳🙂🙂
today:
removed the LP9 harness and direct wired it to the Switch-Pro. I checked with Switch-Pros and they said it is will within spec to do that.
8 years still going!
while I was doing that I also reorganized the output port so switch 1-4 are all low amperage draws and 5-8 are all for lights that require high amperage draw.
and while I was moving the legends around I decided to put these Baja Designs licensed legends on. The only one I couldn't find is "DRL" but that's fine... I'm sure my friend took it lol
but now I have matching legends with my lights.
(sorry auxbeam folks. yall ain't getting these officially licensed legends. maybe someone out there makes cheap replicas like the panels though LOL)
I also didn't find S2 Chase legend for my rear facing S2 so I used REVERSE. Pretty sure my friend took that one too. They do have S1 CHASE and I could swap my S2 for S1 to make it match but those S2 has been with me since 2017 and I'm not swapping those unless I have to.
she's fine.
always begging for food and I get yelled by her dad for sharing (too much sodium for her) lol
*and i meant I actually prefer that way as in the OBS come with us and I gotta pick easier routes lol
she's fine.
I lost track of which post was the pic of Marty..dogs are such awesome companions!
My stock original pirelli's had 6500 miles. I had no issues with them, but how they looked.... So I installed these new shoes/tires on my 2024. 285-55R22 Radar Renegade R/T. Images are are truck a standard ride height, no spacers, no rubbing, no touching upper control arm. Use the Tazer programmer to set my tire size to 34.6 and confirmed speed vs GPS.... and away we go!View attachment 204542
They look great !!!!
First..I didnt realize itd been almost 3 years since I'd posted. I guess that means nothing serious has happened in that time (other than replacing the 8.4 screen due to delamination)..but nevertheless..
Today, I replaced the front speakers. I noticed earlier this week that I was turning the volume up much louder than normal, but figured between being around cars, playing guitars, and having an office next to a scrap bailer that is stupid loud..maybe I was going deaf. I finally moved the balance around and realized it was the DS front door speaker. No heads up of it going out, it just went out. Spent the back half of the week trying to decide whether I need to simply replace, or upgrade. After talk with my engine builder (for the other car, not the Ram) i figured Id just replace and move on. I snagged a pair of JBL 9631s off of Amazon, as well as the adapters and changed the fronts today. It took maybe an hour, but I definitely felt like I was 17 again.
Its not nearly as bassy as I remember, but at least its noise. I'll probably go ahead and order a set for the backs, as I can already tell the backs are quieter than the fronts. I may talk to a buddy who is big into sound competitions and things about adding a small amp & sub just to fill it out, but Ive got an engine to pay for first.
