2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Uhh, that’s great and all, I do hope it “sticks” but what are those shenanigans about your USB C ports only working if cables are inserted in a certain orientation????
I hope you didn’t accept that response
I did not... it only happened one time where USBs where not working. I found a loose fuse. I think they misunderstood my complaint. In fact I found that almost every fuse was loose under the dashboard.
What I find interesting is that the tech said USB-C outlets aren’t bidirectional and thought that was OK to give back to you.
That’s the entire initial purpose of USB-C, not worrying what direction you plug your cord in…
EDIT: maybe I repeated myself. I haven’t had coffee yet 😕
No you are good. I just ignored him. I did not ask them to look at the USBs. They asked me if I had any other issues besides proximity... and I mentioned the USBs that happened once...so I guess they decided to look. My guesses he is confusing USB and USB-c. I have 3 USB lights plugged in at all times that's the only reason I noticed the one time they were not all lite up.
I also told them on the phone that as long as proximity was working I was coming to get it... so he had no choices but to give it back to me.
Went to start up my truck this morning. Dead. Nothing. 4k miles on the 25. Used two different jump boxes as well as jumper cables. Truck starts then shuts off immediately. Any ideas?
Calling the dealership now for another warranty visit but I suspect this isn’t just a battery
Dumb question…. This is a dealer fix, right?
Yes, The dealer reapplied an OTA update... that contained the correction for the Proximity Wake. If the OTA applied like it should have... I never would have had to take it to the dealers.
Gotcha. I got my truck at the end of January, and have never had any OTA updates that I know of.
I've had my Limited since September of '24 and haven't gotten any OTA updates that I know of either. I wish there was a way to initiate the update through the Uconnect system instead of going to the dealer to get the process completed.
I've checked that and it says there are no updates for my VIN. But I think this is just the UConnect software, not the SW for the truck. I think all of the main updates for the truck will come via FOTA.
I don’t know if that’s true.
I know on Ford, all updates came through Sync regardless whether head unit, PCM, BCM etc.
I suspect it’s similar.
FWIW, it’s never said I have an update either.
