Air to coil conversion
Fer’s5thgen
Brand new to the forum not sure if I’m posting this in the correct place.?.? This might have been answered but I couldn’t find a clear answer unless I was looking in the wrong place 🤷🏻‍♂️
I have a 2019 1500 5th gen limited off-road with factory air suspension that I want to delete/convert while also lifting
My primary question is compared to factory coil suspension Do the front struts bags have the same “bolt pattern” as the coil over/strut like will a factory style coil over/ strut bolt right in place of the air strut on the front and will the rear coil mount in the rear bag location with little to no modification?
At the moment the warning messages and so on are not a concern. Thank you
The rear coil needs the factory rubber isolation pad. Others wise all bolts up as normal. You will have to delete the air suspension in the body control module also, or you wil have warnings coming up.
Ok thank you that’s what I wanted to know. Do you know if an higher end scan tool or any programmer or for the 5th gen can delete it?
Look into AlphaOBD or Jscan, security bypass and OBD scanner. Jscan is VIN locked, where AlphaOBD is not.
